todays logs and im not happy with it
Jul 29, 2006
723
cumbria
www.facebook.com
Its the black cylinder with the electrical lead between the two red silicon pipes.
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
so ive already checked it????????
Umm I guess so.....as I said earlier I'm not best person to comment on vag-com logs and from reading other posts on forum I'm not 100% convinced the GS/0.8 is best way to work out the BHP although alot of people on here use it.
Before you done the logs were you happy with the cars performance?
I loose power in the warmer weather even with a FMIC so weather has to be taken into account as does quality of the fuel.....mine runs alot better on Momentum then it does on Ultimate and I'd guess car is set up for 99 not 97 ron?
The Revo map is also adjustable via the SPS switch? so if logs are ok maybe it could be adjusted to suite any changes over the last 5 years since it was first mapped.
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
It's not gospel just an indication, when mapped it supposed to be not as accurate.
Pyro
wouldnt have a clue about map details wasnt happy with the performance wheni first got the car ass was told its was 240 and i cpould tell srtrait away it wasnt :( i know ill loes power in the heat but when i first loged it it was alot cooler and i still got the same resalts
whats the SPS switch?
Smoki333
472
Wiltshire
Pyro - Give me a shout mate, i'll take the dv,Maf off and give them both a clean/service then we'll run some logs again.
I may even try my maf on to see if theres any difference.
Take your Air filter off one eve this week and give it a good clean an make sure its dry before you put it on (It MUST be dry!)
Hopefully we can find those escaped horses! lol
