Using the comprehensive instructions supply with the Andy Mac Stealth Sub I started taking the interior apart ready to fit the sub and the rest of the kit...
Took the front kick panel off from the passenger footwell followed by the sill trim (just the interior one). Then carefully removed the rear side panel... the instructions are clear but you still have to be wary of what you are doing to prevent damaging the panel and its fixings.
There is a big lump of polystyrene behind the rear panel which will be removed so I can get the amp in there..
You can see in the pic below the some what pitiful 'Bose' rear speaker fitted to the rear panel (I have a full Bose system)...
...and here removed in comparison to the Focal I am replacing it with...
...although that too is not without its problems... fitted to the Autoleads adaptor its seems there is a little bit of a gap, I will sort this later with some trimming of the posts and sealant...
On to the sub fitting... I then removed the boot trim where the Bose sub hides... (again, clear instructions from Andy)
...once removed you can see the tupperware (Andy's words) sub in its entirity... clear instructions again on
how to remove it and the mods needed to be done prior to fitting the sub box in...
...next to the AMSS...
...AMSS now fitted in...
...trim panel back in...
...and of course the reason for its being...
Good evenings work, more tomorrow hopefully...
<tuffty/>
