Dropped my car off at the body
shop this morning so they can respray my rain channels for the second time!! thankfully its still under warranty but a pain in the arse non the less... they gave me a 1.2ltr Polo as a courtesy car... brilliant!
Anyhoo... seeing as I had today off so I could do that and some work on my head I got cracking fitting the valves...
Gave the head and the ports a final polish with a scotch bright wheel and cleaned it thoroughly...
...in readiness for this little lot...
Started off by lapping in the inlet valves and then fitted the exhausts which had already been done when the guides were replaced...
I had a small
problem with the exhaust spring lower retainers as it would appear the new guides were oversize and they would not fit over so I open them up a tad and soon had them fitted along with the steam seals...
...exhaust spring set ready to be fitted... these are dual springs, std is single...
...fitting the collets...
...inlet spring set ready to go in...
...pre-fitted the collets as I found it easier to get them seated this way with the tool I was using, they just required a little teasing with a non magnetic pointy thing (I used a cable tie!) to sit in place...
...and there we have it, a blurry vision pic of the supertech valves, springs and titanium retainers fitted
A good afternoons work, and now the head is essentially ready to fit which will happen sometime towards the end of next month all being well...
<tuffty/>
