Found a bit of time today to finally fit the boost gauge pod and wire up the Liquid so that I can still use my OBD port socket for VAGCOM without having to unplug the Liquid...
First the Liquid... Bought 2 switches from Maplins... the rocker is so that I can switch the K-Line between the socket and the Liquid and a locking push button switch so I can turn the power to the liquid on/off if I needed too. I cut a length of CAT 5 network cable as the Liquid uses a CAT 5 plug and socket for a connection...
Decided that I wanted the switches out of the way where they couldn't be seen and where I wouldn't knock them accidentally so fitted them at the back of the cubby hole under the steering wheel where the service books etc go... access can be gained through the holes under the cubby hole...
Wired up the OBD socket so that it would power the Liquid and cut the K-Line so it can be switched...
Plugged it all together and all works just fine...
Next I set to work on the piller pod. I was going to trim it in a similar fabric to the interior but the 2 different bits I ordered where still no close match so I painted it in a flat black that looks rather like the rubber texture of some of the dash elements in the car...
To fix it on the A piller trim I drilled and countersunk some holes and screwed in self tappers. I then filled the screws over with plastic filler, sanded and painted. I applied hot glue to the screws on the other side to hold them in a bit better...
Fitted it all back in the car and doesn't look too bad
And a close up...
All in all a good days work and pleased with the results....
<tuffty/>
