What air filter did you have and which one did you change to?
I think we need to do some logging on the MAF figure and boost with the two set ups on and see if there causing a problemHad an enclosed dynatwist and moved to an open jetex.
Humm
Do you have your OEM airbox?
you will be worried when I walk past you next time at crail thoughNo but I could maybe try and acquire one. It feels superb with the jetex, so I'm not really too worried.
Was your car running for a while, on the RR for a while or very hot prior to you going on?
Might be a shitty fan not supplying enough wind for the open cone and it's ended up sucking in hot air from the engine
lol
LOLNae gonna happen if I get all my parts I have acquired fitted soon
LOL
Will be very close I think, unless you change the turbo
NICE!!! I fitted my VT-FR-ones not to long ago, was done in a couple of hours. Witch brand are these mounts?
Have not tried mine on track yet but I guess it will be a noticeable uppgrade under heavy use even thou we are not on heavy power (yet) as Im also on k03s.
I also did my rear beam mount to VT-ones at the same time, you´ll might consider doing them aswell.
Prebs
Awrite mate, you may want to check this out, was just looking at knockhill videos and came across this, comes up behind your car in the video a lot near the beginning. 'Behind' being the definitive word lol.
http://www.youtube.com/watch?v=C7WsUCK1tE4
That's with shitty brakes too, lol
