Rebuild!
RobDon
Pro Detailer
Wow, amazing price, where was that?
I got the head off today, here's some pics:
http://i312.photobucket.com/albums/ll330/SonicBlueLeon/hd1.jpg
http://i312.photobucket.com/albums/ll330/SonicBlueLeon/hd2.jpg
Check out cylinder No.4!
http://i312.photobucket.com/albums/ll330/SonicBlueLeon/hd3.jpg
http://i312.photobucket.com/albums/ll330/SonicBlueLeon/hd4.jpg
Head disassembled ready for exchange:
http://i312.photobucket.com/albums/ll330/SonicBlueLeon/hd5.jpg
I have decided that I AM going to do rods at this time, not much extra work involved in getting the sump off and removing the rods etc. so would be foolish not to do it now. :D
I'll decide on new rings, honing etc. once I get the pistons out and see what the bores and rings are like - whether they need doing or not.
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Well at least you have found positive signs of a problem.
Nothing worse than removing everything and not finding anything.
Seems like the right idea to do the rods as well. Alot of extra cost but once its done, its done
RobDon
Pro Detailer
Yes indeed, definately alot of oil coming through on No.4 and signs of slight leaks on No.1 and 3 as well. With the amount of work required to get the head off, doing the sump etc. will actually be pretty easy - the timing belt area is just a total nightmare to work on!
Just ordered a set of IE 19mm rods and OE rod bearings direct from IE - £282 including express shipping, so should have them next week. (still cheaper than buying them in the UK!)
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Yeah i thought that....
It seems i rang out 5 places and compared Prices and then they offered a ''CASH'' price Which was the Lowest ....
As your doing the rods dont forget the torco Engine assemble lube as this is what ul Need...at 40k miles i dont thing you'l need to re-ring it and hone it....
You should have a nice Criss cross pattern on the cylinder walls..You don't want it to be Uber smooth and shiny...Glazed..
The Bit for the ARP 2000 Bolts on your new rods are a 11mm 12 multi point socket....
Also Double check everything when doing it...took me 8hrs to build up my bottom end due to keeping it clean and Triple checking everything...
For a bottom end Rebuild you'l need:
Ball multi Alan key Set(Sump)
Piston Ring Compressor
11mm Rod Socket.
Torco Lube
Decent torque Wrench
RobDon
Pro Detailer
Yep no worries, I've got all that already. I've rebuilt engines before, but not for a long time and they were Ford engines. I'll do what Bill said and just rub the bores down by hand, clean and lube them then refit the pistons with new rods and bearings.
wild willy
2,323
Wales
Looking good Rob, watching in admiration. Hope it goes back together a little easier for you. Your in the premier 1.8T modding league now mate.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
Good news on doing the Rods Rob
:thumbup:
will you get hit for duty & vat tho Rob?
:shrug:
Nov 2, 2004
9,335
South Wales
Good work rob, i done the exact same thing when i started burning oil. I just wish i had done more now like valves.
Cylinder 4 is pretty shitty isnt it. lol.
RobDon
Pro Detailer
Well I may just turn this into a longer all winter project and fit valves etc. before next March. The inlet valves are very small and thin, no wonder they break!
New timing belt kit arrived this morning.
csd_19
2,279
28
Angus / Edinburgh
Nice work there Rob! Glad to see you're going to do the rods afterall - are you going to stick a new oil pump in as well?
Hmmmm yeah no. 4 deffo looks like the issue lol!
On the valves, I thought it's usually the exhaust ones that let go? With the 2-piece construction?
RobDon
Pro Detailer
