flip key info thread
Pabs
5,936
Basingstoke
My key blade didn't work first time either - had it cut at Timpsons, and it worked in ignition fine, but not in door locks or boot.
Took it back, and he took "a bit more off" (his words) and 2nd time around it worked ok. It's still a little tight in the locks, but it works, and I'll barely ever use them as I've got remote locking :)
Jan 28, 2009
703
Glasgow
Think i'm giving up on this. Bought a key, turned out to be just a shell. Then realised it is 315 MHz. Presume this wont work?
it does not matter what MHZ it is because you dont have the remote inside it lol, its just a shell makes no difference, im in the same boat
Jan 28, 2009
703
Glasgow
does anyone know if i can buy a transponder for the flip key and program it myself? broke the transponder from my spare non remote key (was glued in)
MadFaz
New(ish)bee
Sep 28, 2008
83
Bradford
finally got the flip key working, had a new blade cut and fitted to the flip key and my friend took 15 seconds to get the transponder out of old key and into the new one!
was a bit of trouble trying to get the spring mechanism to work properly, its about 50% at the moment, still takes a bit of trouble to prop the key up! :confused: but the main thing is, its working :D
Jul 12, 2009
1,484
London
www.flickr.com
So I finally have all the bits for mine now. Still have a few questions as i'm now confused.
I bought a brand new key/transponder/button thing. With this is got a set of instructions as to how to make it work with the car. At no stage is there any mention of taking out the little chip thing from my spare key.
Jan 28, 2009
703
Glasgow
the little chip thing u need out your spare key to start your car, the instructions will be to program it to unlock and lock your car i think
RichieRich
Mk4 Golf GT TDi
Sep 17, 2005
2,367
Oxfordshire :)
www.bebo.com
a chat to a nice person with the correct eqipment to re code the immob (i know of a guy that can do this he is in london tho...) he took off all the keys off my golf there was 4 on the system but i only had 1 of them, he then added a new key (with a brand new chip) and coded it to my car and added auto windows and things like that for me for just £10... i didt think that was to bad to be honest... he can code dials to :)
Quirrel
I used a guy off the internet to cut it.
I think he was mentioned on here before.
Cost 6.40 to cut and have it posted. He did it froma photo.
I couldn't grumble at his service 3 days turn around from receiving the photo
Jul 12, 2009
1,484
London
www.flickr.com
Got the key cut, just another quick questions.
When programming the key to the car, eg: key in ignition, press lock etc... do you put the old remote key that you used all the time, or the spare key with no remote?
Also with the little chip out the spare this will now start the car no problem. I tried without the chip, and it fired up then died...little brown pant moment...
