Is S1 B2 the second Lambda and S1 B1 the First one (on DP?) can somone please confirm as i think this fault is with the secondary which i thought was mapped out with Revo Stage 2?
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
Yup it is a perfect system. I was going to buy a Cupra R bumper to copy Aaron 4-5 months back but prioritized for other things.Nice work guys.
How do you take the lcr bumber off, do you drop the wheel arch liners and unscrew the rails or do you just slide off the rails. (i do the latter)
Is it 76mm alloy bends you use for both air feeds.
For reference just to prove in standard form just how crap the dyatwist is, i ran it tonight in its housing with only a crappy home brew duct pointed at the intake mouth and i barely flowed 200g/sec. In this level of tune i make 218 easily with an open cone.
Twin air feeds as you boys are doing from the fogs is the only way to go, and since the filter is part open to the bay area if ever you hit a deep puddle .... water will just rises to the outside level in the CAI but not progress into the TIP since air will be drawn from the Bay. Perfect.
Ok, TBH i cant remeber what size the bends were now. Nick has a better memory than me. i always find it very difficult sliding the bumper past the headlight and so i always remove the liners and unscrew them.
is the housing still in one piece?
I totaly agree and thats what i have done, im +3'o now with no CFs and getting a bigger nozzle on the way so hopefully push it a bit more.
Im just tempted for when it goes on the rollers to push it highter and dyno from a cooler engine, for better results.
My only concern with a cold air ram intake system is that on the road it will do great as the faster you go the more air it feeds the car, but during a RR the car is static and depending upon the strength and position of the fans used will determine how much air the cars get fed. On a poor RR set up the extra length of the ducting may become a hinderance as little air is being force fed and so the tubby goes into suction mode through a long duct length.
