Just PM me your addy or my e-mail is [email protected] and i will post it to you, it will be buttons for postage. Been lying in my garage since i took off my K03S so its no use to me. I know how desperate you'll want to get the car going.
Just pondering should i keep the valves and OEM springs or should i uprate them both..and raise the limiter a tad...
Could i up the limiter to 8200rpm and use New OEM Valves,springs and seals? or is it a must to uprate the valves and springs?
I would'nt personally run stock valves/springs beyond 7800rpm
you dont even know your power band so a bit early thinking what limiter is appropriate before you see the power delivery
That turbo will be out of steam at 6500rpm.
Thanks bill i wasn't sure so its something i can do after ive got it mapped?
Jamie is was only a questoion you mong xxx
you can change springs later of course, but thinking of your rev limiter that high seems ott for what your spec is likely to deliver. keep the revs down unless you have a fully built motor, with hamonic balancer pulley, and a turbo which justtifies revving to the moon.
mapping will set the appropriate limiter as req'd
Phil W : haven't you got to attend some duties with a sheep somewhere?
