DaNnY_LaD's IHI'd Cupra ( End Of a Eara 08/11/2009)
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Thanks Everyone...
Was up late last night doing some thinking and im gonna carry on with it...
Its the 1st time ive ever been out of a job so i was quite worried of the outcome,So im gonna ride it out and see how its goes..
Bill: Im a Joiner mate so its the 1st think the ressesion hits the builder trade,Ive got a few Numbers to ring today to see what some old friend can offer me..
Fingers crossed i suppose
abdus
have you sold the bits yet? I sent you a text this morning.
if they are still available, text me back. Cheers
jamiebennett81
Yeah But you know your self its hard telling someone than them finding out them selfs
I was like you once, I think your a bit younger than me right? as in making decisions a little too quickly, young un's:cartman:
as hard as it is, it helps to take a step back, think about the whole picture and make decisions with a little time;)
hence why I said sleep on it mate, and make a decision about it in a few days time or at least for all the avenues to be looked into
I am glad you have made the right decision, with all the changes you have made and the one you had finally settled on (BT build), only for a mishap like this to go and ruin it all, would be a massive shame
stick with it;)
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Thanks anton xxx :D
I thought id Better pull my finger out so started at 8am today and ive just finished 5pm...Ive had a very constructive day tbh and very pleased that everything went really well...apart from the ****ing oil line i might have swore a couple of hundred thousand times but got it on in the end...
First job of the day was to get the Gear linkage bracket on which ended up me having loads of room for a Large 3'' tip all the way down to the compressor wheel which then in turned in to 57mm around 2'' away from it...
The Bracket which i copied for anyone who might want it..was a peice of piss to fit i couldn't belive it..
So i got all the coolant & oi lines on,Cut and Mounted the Tip,Fitted Gearlinkage bracket,Fitted ECS thermastate & Sump plug,Bolted turbo up,Fitted walbro Fuel pump & braided lines with finishers..
All ive got todo now is tidy up the wiring inside the Car and engine bay,Fit 1 oil banjo bolt to the block,wirer up walbro then fill her up with oil and start her up...
Seems to be alot going on in the bay but theres no way to smartan it up abit...I could tidy it up abit but im gonna leave that for another time...gonna get ready and go to the pub :D
EDIT:
Also im looking for some Prober bolts for the manifold to Turbo as the once ive got aint any good...
would these work even tho they aint a HEX pattern
http://cgi.ebay.co.uk/M10-x-25-HIGH...66:2|39:1|72:1683|240:1318|301:1|293:1|294:50
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
personally I would not use an allen head cap head bolt for that use.. if you needed to get them off at a later date the heads are far more likely to strip and then you will be stuffed
