has it seized Dave?
Nae good Dave.
Got warranty on this?
Bad times mate![]()
not good dave. Hope you get it in time mate. Was not running on the last RR day? Was that not a while ago? Did you not notice the meth lasting a long time
I'll give USRT one last chance - which means phoning them PM due to the time difference......
Last weekend, Nick.
I really need to get a fail safe device to cut the boost if the wmi stops flowing, I'm lucky nothing nasty happened because it was running a shedload of advance.
Iv advanced mine now and like the sound of this device? How does it work? Flow meter linked up to somthing?
Flow meter linked to a solenoid operated dv. I'll keep you posted. Yes pleasei was thinking about this whilst straitening my hair, surly you would need some brain behind it, as it not flowwing all the time, and you would need the brain to know what boost you are running. Then the brain can go Oww over X PSI and yes im getting a nice steady voltage from that spinning thingy so ill keep the solenoid where it is. Or does over straightening your hair make you over think?
![Cool [B)] [B)]](/forums/styles/seatcupra/oldforumsmileys/shades.gif)
bigger nozzle = more power I presume? Dave as we discussed you need a diff![]()
