MOT passed this morning, not a single advisory. :funk:
Remembering 100 cell cat - on its fourth MOT, running high power for the last year with methanol thrown in......
Fast Idle actual limit
CO 0.19% 0.20%
HC 65ppm 200ppm
Lambda 1.01 1.03
Natural Idle
CO 0.02% 0.30%
:cartman:
wicked Dave :)
.....Not bad price for the performance gains though.
Yea, I think it is very good price for the gains too mate. Once it set up correctly the gains are very impressive, not ot mention the cooling it extra gives (cheaper than the new cooler you were looking at).
Might be worth droping Probee a PM and ask him where he got his kit from.
Where you buying your kit?
DPJ, got any pics of your WMI install? You have it hooked up to your plastic washer tank yeah? I read that you can't use alloy tanks because methanol corrodes alloy. Also read this: "If you use the stock windscreen reservoir, remember that many fumes will enter the cabin. Methanol is toxic, and doesn't smell."
My washer tank is in the boot now, which is making me think twice about this now! The info was off the Aquamist website.
Rob, not much to see on my install.
Remember the original sidemount LC intercooler bracket? It makes a perfect bracket to hold the Snow pump - in the same position.
Yes, I'm using my washerbottle (and thanks to Rainex, use my washers as little as possible :blink: ) I drilled the bottom of the bottle and there's a pipe straight down to the pump. Then piped pump to injector nozzle.
I'm looking at putting a bigger tank in the boot now so I can return my washers to the washerbottle - and go longer between methanol fills. I may dispense with the rear washer so I can use the front/back tubing for wmi. I have found several useful plastic boat fuel tanks online to chose from. :cartman:
