I think it should be a little higher, Danny. I'm making ~175g/s and I'm only making ~225-230bhp. There are people making circa 200+g/s on k03s' so I'd expect around the same from your turbo.
But people aint using a 3'' maf housing though
An intake gasket isn't going to solve the problems you're seeing Danny. Your airflow figures indicate that you're not producing the power, based on the Maf sizing info you gave me.
Danny, what size injectors are you running?
1.2 bar held between 6-7000rpm is about 220g/s. Chances are your maf wasn't rescaled when you had it tuned on a 3" housing.
Get some decent fuel in it and it'll be fine.
the rescaling is done in the software.
So is the reading Fine?
my Maf reading wasnt rescaled when it was mapped..
Is mine holding 1.2-1.3bar at 6-7krpm then? Which is roughtly 220g/s?
It is in no way shape or form slow.
i wanna make sure its spot on before i do that jamie...
dnt wanna do it if its slightly pulling back ect...
