Told y'all - high oil pressure ... it needs a restrictor or it will just happen again. Mine was all smoothed out inside too when they did the hybrid on mine.
Yeah they said that Rob..
It was Oil Pressure and Oil Contimation From either Cupra_matt Or beattie17 car Which then eat away the Bronze Impeller Bearing which Prober F**ked things up really bad.So i had needed a New Shaft,Backplate,Uprated Seals,Larger Compresser Wheel,Bearings,Bronze bearing ect
Plus a genral Service and Port & polish
So He's Fitted it with a 1.5mm Oil pinion to reduce the Oil pressure but it will still Lube the bearing ect...
