Bit of good and bad news..
Mark has full stripped it down and this is what he wrong to me via email...Ive no Paid for it and should be here tomorrow
Hi Danny,
The turbo will be ready today, it can be sent out tonight to be with you monday.(or saturday delivery is £20)
The overhaul was a little more than just the bearings and seals, the turbo has suffered some oil contamination causing damage to the shaftwheel. The wear on the shaft and bearings would have been what led to your smoking issues.
As we are changing the shaft and backplate as well as just the service items we are going to be looking at £295.
I will still include the modifying of the oil inlet and porting of the turbine housing. And the unit will be fitted with the uprated thrust bearing.
I would recommend flushing the oil and changing oil and filter before refitting the turbo.
Mark
So i rang him up and hes added a larger compressor wheel for free to...as the price was more than id expected...
So its had
New Seals & bearings
New acutator spring
Port & Polished
Larger Compressor Wheel
360d Thrust Bearing
Bronze Bearings
Oil Restrictor
New Turbine
Larger Exhaust Hot side(ported)
New Nuts and bolts
He said the cause of the seals failer was Oil pressure and Oil contimate So either Matt_cupra or Beattie had something in there oil(metal) which at 60psi oil pressure had Eaten away My bronze bearing..SO the how unit had failed...
So its Kinda a hybrid but with a Clipped k04 wheel He said the Gt2x is far more advanced than any KKK range of turbo..He said a Gt2x Is basically a K04 Hybrid....But the Narrowness and rought cast would not
help Spool/Gases to flow enough....
That guy Defo knows his turbos lol
He also Said the Gt2x is a very good turbo But the quality is shocking...He said the seals they used wernt efficant for a turbo...So hes using some wrc ones which are nice and thick..
