I believe he runs stage 2 Revo, John.
Hi john, thank you for taking the time, I've read your posts in the past and you really do know your stuff![]()
I run a little less than 15% of peak fuel flow at 50:50 w:m. .......
Interesting point about Load based dynos - wonder if this is why stage 1 cars make near enough the right power and the stage 2+ brigade always seem to be out by more than they'd like?
Of course the theory is nonsense![]()
Aaron is it not just possible that whilst you need to adjust your WMI to get the right mix at the right rpm etc etc going on what the logs tell you ... but that the actual loss of power is really something the dyno showed that isn't actually a real loss? And by fixing what you guys are talking about will make things run correctly and show correct ( safe ) log figures but won't nescessarily affect a Dyno plot? On the road on the way down it seemed just as quick as usual ......
I won't attempt to get into the tech stuff as i could write all i know about that on the back of a stamp in a thick felt pen![]()
me too lol the leak was a def loss of power i was meartly making the enquirey lol
taking her there next week to see whats what,
although sometimes i do wonder about rollers in general my mates lcr ran 232bhp and 240lb ft torque but stays near as damit with remapped lcrs and is way faster than standard ones but i know before he killed me but now i can stay woth him
next meth lol but i am going to stop blaming maz for my spending and turn it to you lol
Hehe you can't blame me for the spending although I was very impressed by the diesel Ibiza running 250bhp and 400lb/ft..... That was running meth
Dave
Peak fuel flow is 630cc*4, as i'm touching 100% duty cycle at 7500rpm, so 15 % would be 380cc of water. I'm about 350cc when i measured it, so close.
From memory aquamist say 10% for water and 15-20 for a 50:50 mix, but i've got their basic system maxed out. It's fixed volume as well so to give me gains at the top end it may be costing me a little mid range, but flow goes from 100g/s to 180g/s (14lb to 30lb boost) in 450rpm after injection starts.
My system is far from perfect, but I do achieve good timing advance. I don't think you'll get that much on a small port, maybe into the low 20's, but knock sensors will stop you before you get there unless your tuner will reduce their effects. They are over sensitive, but are there for safety so you can understand that.
Tuners will always er on the side of caution as they don't want customers coming back with blown up engines when a sensor goes tits up and they are too close to the ragged edge.
Mine knows that if it blows up, it's my problem, and I'll fix it.
As for injecting too early, buy a switch off aquamist and set it to 12-14psi, unless you have a maf or injector signal driven system in which case you can start earlier as you won't inject too much at low rpm (low fuel flow)
Friday 6 March 2009 07:13:13
1ML 906 032 A 1.8l R4/5VT 02 0001
Group A: '002
RPM Load Inj Mass Flow inj duty %
TIME
MARKER STAMP /min % ms g/s
1113.93 2120 13.5 0 5.56 0
1114.33 2040 13.5 0 5.22 0
1114.74 2000 15 1.7 5.86 2.833333333
1115.13 2000 37.6 4.76 22.03 7.933333333
1115.54 2080 63.9 6.12 28.69 10.608
1115.94 2160 60.2 5.1 24.75 9.18
1116.34 2200 46.6 4.08 16.17 7.48
1116.76 2280 46.6 4.42 21.47 8.398
1117.16 2320 58.6 5.1 28.61 9.86
1117.56 2440 62.4 5.44 30.83 11.06133333
1117.96 2480 63.9 5.78 33.19 11.94533333
1118.36 2600 65.4 5.78 33.86 12.52333333
1118.76 2720 74.4 6.8 40.78 15.41333333
1119.16 2840 86.5 8.16 49.19 19.312
1119.57 2960 94 8.16 54.22 20.128
1119.97 3120 96.2 8.84 57.83 22.984
1120.37 3280 97 8.84 62.19 24.16266667
1120.77 3440 103.8 9.18 70.56 26.316
1121.17 3640 109 9.52 76.47 28.87733333
1121.57 3800 103 9.52 78 30.14666667
1121.97 3960 95.5 8.84 72.61 29.172
1122.39 4120 92.5 8.16 77.61 28.016
1122.79 4280 102.3 9.52 89.25 33.95466667
1123.19 4520 150.4 14.28 162.31 53.788
1123.59 4760 180.5 18.36 166.42 72.828
1123.99 5120 178.9 18.02 173.67 76.88533333
1124.39 5360 175.9 17.68 177.03 78.97066667
1124.79 5600 169.2 18.02 179.31 84.09333333
1125.2 5800 163.2 15.98 184.58 77.23666667
1125.6 6040 163.9 16.32 182.14 82.144
1126 6200 141.4 12.58 180.94 64.99666667
1126.4 6400 148.9 14.28 183.08 76.16
1126.82 6560 144.4 15.64 183.33 85.49866667
1127.22 6760 122.6 12.24 181.56 68.952
1127.62 6880 146.6 14.62 184.61 83.82133333
1128.02 6600 12.8 1.36 0 7.48
1128.42 5360 88.7 9.52 119.25 42.52266667
