Feb 27, 2007
1,261
Behind Wilko
I Finally got around to doing some logs and changing some settings with unisettings.
i finished off my last tank of meth with a 20% mix and it really didnt feel good so i went the other way.... at 50% the car felt so much more eager so the butt dyno won for these logs.....
the annoying thing is i think my MAF has gone, ive never seen it run with figures that low before. recently they have been up to 217g/s so something must be wrong?
i think i might go back and put the fueling back to standard as its not making a huge difference....also, does the boost seem a littlelow for B9... isnt that normally over 1.5bar ish?
Code:
Tuesday	3	March	2009
1ML 906 032 A  		1.8l R4/5VT      04 0001
(-1.3% FUEL  0 TIMING 50%WMI B9 T9)
	Group A:	'031		Group B:	'115				Group C:	 Not Running
		Lambda	Lambda		RPM	Load	Abs Pres.	Abs Pres.
	TIME			TIME					TIME
MARKER	STAMP			STAMP	 /min	%	 mbar	 mbar	STAMP
	32.17	0.961	0.945	32.59	1400	22.6	970	990
	32.99	0.844	0.945	33.39	1400	67.7	1050	1030
	33.8	0.977	0.953	34.2	1600	57.1	970	1100
	34.6	0.922	0.953	35	1720	45.9	970	1080
	35.4	0.953	0.945	35.8	1840	43.6	970	1050
	36.2	0.953	0.953	36.62	1960	36.1	970	1030
	37.02	0.953	0.945	37.42	2040	36.8	970	1020
	37.82	0.945	0.945	38.22	2160	37.6	970	1020
	38.62	0.953	0.953	39.02	2240	37.6	970	1020
	39.43	0.961	0.961	39.82	2400	70.7	1440	1110
	40.23	0.961	0.977	40.63	2720	101.5	2000	1510
	41.03	0.984	0.984	41.43	3200	157.9	2360	2310
	41.85	0.945	0.938	42.23	3880	178.9	2480	2430
	42.65	0.883	0.875	43.05	4520	176.7	2440	2470
	43.45	0.883	0.86	43.85	5040	175.2	2430	2390
	44.25	0.852	0.86	44.66	5520	159.4	2360	2320
	45.06	0.836	0.86	45.46	5960	156.4	2270	2230
	45.86	0.852	0.86	46.28	6320	150.4	2190	2160
	46.68	0.805	0.86	47.08	6640	140.6	2160	2200
	47.48	0.75	0.899	47.88	5920	88.7	2130	1230
	48.28	0.945	0.891	48.68	5480	163.2	2340	2260
	49.1	0.844	0.86	49.48	5720	154.1	2300	2320
Code:
Tuesday	3	March	2009	22:03:17
1ML 906 032 A  		1.8l R4/5VT      03 0001
	Group A:	'003				Group B:	'020
		RPM	Mass Flow	Load	Ign. Timing		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
	TIME					TIME
MARKER	STAMP	 /min	 g/s	%	 °BTDC	STAMP	 CF	 CF	 CF	 CF
	289.23	1800	5.22	5.1	4.5	288.83	0	0	0	0
	290.05	1720	5.08	4.7	33	289.65	0	0	0	0
	290.85	1680	5.36	4.7	32.3	290.45	0	0	0	0
	291.65	1600	5.81	5.5	33	291.26	0	0	0	0
	292.46	1640	10.11	8.2	33.8	292.05	0	0	0	0
	293.26	1680	10.78	9	35.3	292.86	0	0	0	0
	294.06	1760	11.58	9.4	35.3	293.66	0	0	0	0
	294.88	1920	20.83	15.7	30.8	294.48	0	0	0	0
	295.68	2160	22.11	15.3	32.3	295.28	0	1.5	0	1.5
	296.49	2440	30.08	19.2	31.5	296.09	0	0	0	1.5
	297.29	2760	35.75	20	33	296.89	0	0	0	0
	298.09	2520	4.39	5.9	0	297.68	0	0	0	0
	298.91	2120	34.58	30.2	25.5	298.49	0	0	0	1.5
	299.71	2360	40.94	32.2	25.5	299.31	0	0	0	0.8
	300.51	2640	45.42	34.1	27.8	300.11	0	0	0	0.8
	301.31	2920	73.25	98.8	28.5	300.91	0	0	0	0.8
	302.13	3440	125.97	100	9	301.71	3	0	3	0
	302.93	4040	138.69	100	13.5	302.53	3	3	3	0
	303.73	4640	151.39	100	15	303.33	2.3	3	3	0
	304.54	5160	167.97	100	12.8	304.13	2.3	2.3	2.3	0
	305.34	5600	177.75	100	15.8	304.94	2.3	1.5	1.5	0
	306.14	6040	178.31	100	16.5	305.74	1.5	1.5	1.5	0
	306.96	6400	184.22	100	16.5	306.56	0.8	0.8	0.8	0
	307.76	6360	0	6.3	6.8	307.36	0.8	0.8	0.8	0
i thought id log block 66 for some fun.... there was loads of standing water tonight so it might not be the best test but still here are the runs
Code:
Tuesday	3	March	2009	22:10:29
	Group A:	'066
		Speed	Bin. Bits
	TIME
MARKER	STAMP	 km/h
	88.51	82	0
	88.91	86	0
	89.33	91	0
	89.73	97	0
	90.13	102	0
	90.53	107	0
	90.93	112	0
	91.33	117	0
	91.73	121	0
	92.14	125	0
	92.54	129	0
	92.94	133	0
	93.34	136	0
	93.76	138	100
	94.14	139	0
	94.54	141	0
	94.96	144	0
	95.36	148	0
	95.76	151	0
	96.16	154	0
	96.56	157	0
	96.96	159	100
	143.62	95	0
	144.04	99	0
	144.44	103	0
	144.84	108	0
	145.24	113	0
	145.64	118	0
	146.04	122	0
	146.46	127	0
	146.86	131	0
	147.26	135	0
	147.66	139	0
	148.06	143	0
	148.46	146	0
	148.87	149	0
	149.27	152	0
	149.67	155	0
	150.07	158	0
	150.47	161	0
	150.89	163	0
	151.29	166	0
	151.69	168	0
	152.09	169	100
	186.27	30	0
	186.67	39	0
	187.07	45	100
	187.47	46	0
	187.89	50	0
	188.27	57	0
	188.69	68	0
	189.09	78	0
	189.49	86	0
	189.9	88	100
	190.29	90	0
	190.7	94	0
	191.1	99	0
	191.5	105	0
	191.9	111	0
	192.3	117	0
	192.7	122	0
	193.12	126	0
	193.52	131	0
	193.92	133	0
	194.32	136	0
	194.72	140	0
	195.12	143	0
	195.52	147	0
	195.94	150	0
	196.34	153	0
	196.74	156	0
	197.13	159	0
	197.53	162	0
	197.93	165	0
	198.33	167	0
	198.75	169	0
	199.15	172	0
	199.55	174	0
	199.95	176	0
	200.37	178	100
	200.75	178	0
	201.15	178	0
	201.57	180	0
	201.97	182	0
	202.37	183	0
strugers1
i am very inpresse with your car mate its mental
how long oes the meth last??
mrwookie
Big Daddy...
Mar 22, 2008
716
Cambs & Herts
Hmmm looking at your logs mate it doesn't look with regards to your MAF. Not that its an exact science but I would say looking at the readings of your MAF its coming out that its runnning around 240ish bhp which clearly isnt right.
Is it running like dog with 3 legs at the mo?
Oh and 114mph........naughty boy! ;)
Feb 27, 2007
1,261
Behind Wilko
:D ta matey..
regarding meth... it last quite a while but its dependent on the strength. i probably use about 5ltrs for every 60ltrs of fuel....thats a guess.
i was suspecting something was wrong with it Ed as on the way to AMD the other week someone pointed out that i had forgotten to plug my MAF back in and i hadnt noticed the difference...... this just sort of confirms it for me, it flowed more as a standard car :(......that said though, it doesnt feel slow at the minute.
lucky i have the hangers near me....i would never do those speeds on a public road :).
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
(Quickly) Boost is requested, then actual. (Map sensor =2540 max reading)
You'll only get advantage from a 50% meth mix if the engine is burning it and your timing needs to be advanced quite a bit to do so. Your timing doesn't look advanced to me.
It also looks to be running a bit lean. Sorry I haven't come back earlier, I'll have a good look tonight.
1,261
Behind Wilko
Thanks Dave.... are you saying im not even requesting the right boost?
The fueling isn't too bad is it? I will add some later (it's not my daily driver) but it didn't seem dangerously lean.
The Maf can't be helping.. I need to get this sorted. how much of a difference do you think this is making?
i do underdstand what you are saying about the 50% mix, it just feels so much better this way. i tried pushing the timing more but had the same problem as you.... i wasnt seeing a difference in fueling and was getting a load of CF's. i spent ages last night playing and in the end thought id give the car a rest. this is going to sound like a stupid question but what is the real difference, if im not burning all of it, wont i just be using it to cool the charge like i would if i ran ran more water (although a weaker mix is obviously cheaper)
neon
Hey probee loving your car! Can I ask where did you get your cold intake feeds for the induction kit. Cheers.
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
I don't quite understand why you've taken some fuelling out. A failing Maf could be causing it to run a tad lean.
Before you write the Maf off, I'd redo the runs with the wmi switched off, just as a check.
When I took mine to a JBS RR day with the wmi newly fitted, midway through my development, I thought it felt fantastic running 50/50 wmi. However on the rollers we quickly proved it was running 30bhp less with 50/50 wmi on than with the system turned off altogether............
The only way you get to burn the methanol is by advancing the timing. When you're ready, I'll post you a ref to some calcs on this.
You'll cool the charge injecting just 0/100 = water. A 25/75 mix will give you great intake temps - any more the this and you won't see your intake temps dropping - try logging 032 to see. Unless you can burn the extra meth, it's probably just quenching the combustion.
