flip key info thread
rk696
683
West Yorkshire
You need to have a key with an original transponder chip (little glass cylinder) in the ignition, and turned on.
It shouldn't matter is the new key you are trying to code to the central locking has a transponder chip or not, that's only used for actually starting the car.
You have to (iirc):
1. Turn on ignition with original key, and leave it in.
2. Lock the door manually (i.e. put key in lock and turn it) (Might also be a good idea to have the drivers window open!!)
3. Press unlock on the new key(horn should blip, but mine didn't. :confused: Wait about 5 seconds and then press unlock again. The doors should unlock.
4. That's it!!
All you need to do then is get the key cut somewhere, swap the transponder chip over from your old key and you're sorted. :thumbup:
rk696
683
West Yorkshire
im soo confused, do u just get a key with the same MHz rate as your and your good to go or does this part number thing matter, surely the Mhz is so the trasmitter responds to the key, nothing else should really matter i wouldnt think, all the paert number will be is the one for whatever style of key you have i would be thinking
I think the part number is more important than the MHz rating TBH, all of them transmit on 433.92 MHZ anyway. I tried two different keys on mine, and they were but 433MHz, and only 1 worked. Depends on the age of your car I think. They must transmit a different signal, albeit on the same frequency.
JackFS
anybody know where i can get a new transponder instead of going to Seat? I got mine out and lost it completely and now my new flipkey won't start the engine. Seat want £40.80 (rip-off) so i don't know where else i can get one!
Also i don't know why the transponder in the Brand new key won't just program to my car! Technology does my head it in. Any replies? Cheers guys
chris1903
Wish this thread could be compressed, falling asleep reading through it lol!
My original key doesn't state what Mhz it is on the side, any other way to find?
RichieRich
Mk4 Golf GT TDi
Sep 17, 2005
2,367
Oxfordshire :)
www.bebo.com
hi guys does any1 know how you can swop keys with only 1 transponder as my golf didt come with a spare key :( i have a spare flip key from when i did this to my ibiza but i had a spare to do it with :) also the part number is HL0 1J0 959 753 A do i have any luck? its a year 2000
RichieRich
Mk4 Golf GT TDi
Sep 17, 2005
2,367
Oxfordshire :)
www.bebo.com
i have tried it once with no avail.. i have got another transponder also but how do you pair it with one key? how do use the one i already use? and if i break it getting it out ill be a bit stuck! :(
Chemical Al
Trollied Member
Apr 6, 2004
2,043
Craven Arms, Shropshire
what i would do is get your self a key cut then try and get the remote part working, most of the remotes will clip into the standard key balde Y part so if yours doesnt work then pop it on ebaty and get another
RichieRich
Mk4 Golf GT TDi
Sep 17, 2005
2,367
Oxfordshire :)
www.bebo.com
i have a key cut and its already fitted into my new flip key inc my new transponder, have tried to get it to program also. my old key is a different shape to the one i have now it has the rounder buttons insted of the squarer ones? mine has a A at the end if this makes any difference
puntoii
Hello Guys,
can somebody tell me please the remote control number for flipkey for Seat Ibiza 6L,year 2008 ?I need only the numbers,2 or 3buttons ?Seat or VW number.I have bought 2types of remote control,bud doesnt work :(
Thank you very much and sorry for my bad english
Ronald - Slovakia
Chemical Al
Trollied Member
Apr 6, 2004
2,043
you can program the remote with what you have (original key in ignition, new one in door) but the immob requires a SKC and vagcom or a dealer
RichieRich
Mk4 Golf GT TDi
Sep 17, 2005
2,367
Oxfordshire :)
www.bebo.com
hi chemical al, no it wont work not even with vag com the car wont reconise it at all lol the immob works with my car can also start it but the buttons dont work the red led flashes so its not the battery either :)
puntoii
Remote Control ,, 1J0 959 753 AH /Volkswagen/ ,, spared with Ibiza 6L 2008 without problems on VAS.
Thank you RED IBIZA !
Ronald - Slovakia
