rob have you seen this site - http://www.tastynuts.com/site/frameset.htm
Thanks for posting that link, I need a set of coloured bolts myself
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
Thanks for posting that link, I need a set of coloured bolts myself![]()
Anyone know what the time/labour cost involved in having a set of IE/Stone 19mm forged rods installed is? I'm guessing it's alot based on stripping the engine and rebuilding it with the new rods and bearings? Fancy having these fitted when the baffled sump goes on.
i paid £857 inc vat to have my rods fitted nearly 4 years ago now.labour was £544,parts were £184.both +vat,hope this helpsAnyone know what the time/labour cost involved in having a set of IE/Stone 19mm forged
can I ask why you need rods Rob, as I thought this was only needed for BT applications?
Thinking into the future really, there isn't much point in me going for a 325bhp BT kit as the increase in power isn't that much over what I have now, but if I had rods that would lift the restriction and allow me to go for a 350 or even a 400bhp kit in the future!
Haha yeah, a few tempting motors out there but yes, I'll be keeping this car for a long time yet, it's still only got 37k miles on it, not bad for an '01 car!
BT is certianly something I would consider for sure!! but my car will have something like over 100k on the clock, and not sure its wise to put her through that sort of power leap to 400bhp, even WITH uprated rods, pistons etc?
Nothing much new to report, my car is in for its MOT today, I poured some Forte emmissions reducer in the tank to make sure it passes the emissions test, it should as I use Tesco 99 which has lower emissions than Shell V-Power. I always turn the boost down too to make sure nobody from the garage gets full power, the young mechanics eyes always light up when I drop my car off - as they did this morning!!!
I'm currently running a K&N Apollo enclosed induction kit, with a direct cold-air feed off the foglight hole, doesn't feel restrictive and gives higher g/s due to the air being force-fed into the filter, if anything feels slightly better than the open cone, downside is no noise! Back to the Forge 007P DV too, car runs smoother with it.
Rob - with a feed fully attached/sealed to the airbox, I'm sure mine would "get going" marginally quicker. Say if you're doing a steady 40, then accelerate, it would jump forward more eagerly. This makes sense in connection with "ram-air" theory (although I would say that the fog light isn't the best place as you want the highest point of pressure at the front of the car, which is usually just above the bumper line).
Anyway - later, I had the air feed disconnected from the airbox, probably just with a few mm gap. The induction noise came back, the peak g/sec increased and I don't really remember loosing the eagerness, but as that was "seat of the pants" it was hard to measure.
Turbo theory says that increasing the pressure on the "outside" of the air filter helps significantly, as the turbo has less work to suck the air in, is more efficient as a result, and so can spend more effort producing boost, or producing same boost at lower temps.
All very interesting, but real world practical difference? Dunno. Like John always says, you can always bolt a bigger turbo on...
