I undid my oil feed line from above, I have a padded mat I lie across the engine with, taking care not to lean on coilpacks, fuel lines etc. so as not to break anything and I got to mine ok.
Same here. In spite of that, I had a lovely collection of bruises across my chest after changing my turbo.
No, it's not easily accessible from below.
hmmmm ok, thanks Dave
I meant that it's a job that's done from above.
Rob, is that exactly the same as the JBS one? looks very similar....
They're studs m8, you can't fit bolts in from above so you have to use studs and nuts, the studs will go into the turbo first. It will have to be assembled on the bench, not on the car.
They don't - screw the studs into the turbo first then slide the gasket and manifold on top of the studs and do up the nuts?
This is what I need this extreme temp thread lock for, so far only INA has it.
