Arbs R Us!
Anti Roll Bars
Having done the suspension and getting a good set of tyres to match, there was always something missing. I noticed it more especially since I had the pleasure of being driven in probably the best two Leon TDIs on this forum - Slick (Rodger) and Unclefester (Pat).
When going around roundabouts and long sweeping bends the car was losing traction sooner and more sudden than Slicks and Festers. The reasons for this were that more weight where going on the outside tires and less weight on the inside tyres which caused the car to lose/reduce traction suddenly.
Results
Traction, Stability and predictability!
First thing you notice when you drive off is how much more stable the car is when turning. When the car was standard, I showed Pat the limit of the car when coming off the exit of a large round about. As Pat described it, "the cars rear end wanted to play games". With the ARBs on the same exit and same bend the car was so much more controlled, predictable and glued to the road! I was like WOW they actually do make a difference.
I simply cannot believe how essential the ARBs are to the Leon!
Part No
Eibach ARB Kit 25mm 40-85-005-01-11
http://eibach.com
Pictures
Car when being lifted up before surgary (she was scared as you can see)
Old front ARB doesnt look upto much
Thicker Eibach front Eibach Arb looks purposeful
Rear ARB (excuse the weeds - weed killer will sort those
