i've covered 204,9km
Cold start is great without any noises and vibrations, oil and water are on spot.
Finally i installed my EGT gauge, car idles (hot) @ 300°C and on cruising the max (5th gear, 3000rpm, -0,1bar,uphill) is 560°C.
I replaced the blue spring in the dv006 with the green one, i hope now to open easier...
The car for now runs with stock TT225 inlet hose, i hope this week to install the chargecooler and make a metal intake pipe (76/80mm) and put the filter under the battery base.
The only prob is that the steering fluid tank must be relocated to fit the chargecooler core and pass a 76/80mm tube behind it.
I've also bought an oil catch tank and i must find a place to fit.
