Nearly there with the brake setup now! I fitted my huge concoction of brake parts:
- Aston Martin DB9 Calipers with balance pipes reversed (these were from a VBT kit)
- HEL braided lines
- Audi RS3 carriers
- RacingLine floating bells
- Reyland Motorsport custom machined 370mm plain discs
- VCDS coding for 370mm setup
I had actually ordered and received VHT gloss black, clear lacquer and Brembo decals to re-finish the red RS Brembo calipers I had been using to mock everything up, and I was planning on cleaning them up, sanding them down to paint them over the last week or so, but was waiting for dry weather as I don't currently have anywhere inside suitable for painting at the minute. After receiving all the parts, a full Aston Martin Vagbremtechnic setup came up fairly locally on Marketplace, with little use, and nearly new 345mm discs and Ferrodo pads (need to check this when I fit the disc guards). I got this set at a great price, just missing the carriers, which I don't need with my RS3 carriers and new Reyland discs - although it would have been a great value for money kit if I hadn't just spent more than the whole kit on the Reyland discs, as I could have just bought the 345mm carriers cheaply when they are back in stock!
Although the Aston Martin decals aren't my favourite thing, I was drawn to having factory finished black calipers, and the fact that I could bolt them straight on and go without any issues. If I choose to re-finish them to have Brembo decals in the future, at least they're black to start with, so no chance of any red coming through if chips occur etc... I'll either sell the red RS calipers as a complete bolt on with with the 345mm discs and brand new carriers when they're in stock, or perhaps re-finish them in black with Brembo logo's as I have all the paint now, and see how they come out.
Here is the kit:
Here's the Brembo/RacingLine/Reyland motorsport concoction all installed:
Nice and snug under the stock wheel with a 15mm spacer - I think 12mm would work, but 15mm front and 20mm rear suit the stock wheel setup and was how I had it with the stock brakes anyway.
Should really clean the car!
Lots of brake parts to clean/re-finish and sell now!
Next up will be brake disc guards, Just need to modify my TTRS disc guards, or buy later RS3 guards now, and i think I'll be done brake wise (hopefully anyway!)
After that the list looks something like:
Current list to do:
- Wash and machine polish whole car
- Investigate slight exhaust blow
- Sort VAQ issue
- Fit right hand exhaust heat shield
- Fit sound deadening to boot floor, and golf estate spare wheel well carpet
- Fit 370mm disc guards (bought from a TTRS part no and they don't fit!!)
- Try and code the car to remove any faults
- Fit Virtual Cockpit (purchased) and MIB2 unit with MOST port
Then longer term things:
- Upgrade audio with Seat Sound
- Fit reversing camera
- Do a black/alcantara roof lining conversion
- Try and find
Cupra Estate alcantara door cards (facelift)
- Change seats to something nicer & heated
Seems never ending!!
