where do you plumb your catch tank into
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
have done a search but cant find that more clearly
any pics of this would be grate
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
it replaces the black valve on tip (looks like a DV but not one)
so instead of it running to that, run it to the tank and put a filter on other side of tank and blank off the tip
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
yea i know that u have to block that bit off on the tip but where do the pipe from the catch tank go to?
like i said pics would be good
StanTheMan
Take off the mushroom you remove from the tip, and the pipe left goes into the tank.
h17och
Sep 1, 2005
3,504
Dunstabubble
a frsh pic just taken
see tank in front of filter
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
o right i thought that there were two hoses comein out of them
unless im blind n cant c that theres two
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
so basicly the one on the left into the tee thing lets call it and the other pipe basicly just vents ,is that right?
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
Bill's run's off the rocker cover:
mine runs off both front breather block, no PCV fitted at all, no connection from inlet manifold to breather systen on mine. There's a T piece you cant see by cyl 3/4 which joins the pipe from the rocker cover.
my catch tank with filter breather also has drain pipe in its base back to sump. (SEAT Sport baffled sump)
made for me by Forge Motorsport
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
what is a pcv
will it be ok plumbed into the tee and the other one just venting
sorry bout all the ?s ant dont realy know much about these catch tanks n how they pipe in, but they r a very good idear because the last cupra i had when i fitted a TIP to it i noticed abit of oil n gunk n dont want this to happen to my new one so i have a catch tank on the way n just need a lil help on where to plumb it in
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
what is a pcv
The Positive Crankcase Ventilation valve (PCV) is an emissions control device that routes unburned crankcase blowby gases back into the intake manifold where they can be reburned. The PCV system is one of the oldest emission control devices, and also one of the most beneficial. Besides totally eliminating crankcase emissions as a source of air pollution, the constant recirculation of air through the crankcase helps remove moisture which otherwise would cause sludge to form. Thus the PCV valve extends the life of the oil and engine. The PCV valve requires little maintenance.
The PCV valve is the thing that looks a bit like a dv - plugged into your tip. Take off the PCV valve and connect the pipe it was on to the catch tank. Connect a small filter to the outlet on your catchtank (or connect to the TIP),
