where do you plumb your catch tank into
Nov 2, 2004
9,335
South Wales
And mine is. Just uses the OE pipework at the side of the block.
Dave, the PCV valve is under the manidold looks like a T-piece and is prone to break and leak boost.
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
I've got a comprehension problem over discarding the PCV system and replacing it with a breather / catch tank system.
As I understand it, PCV systems flush the crankcase with fresh air and then by drawing it into the intake system. Careful design ensures this does not upste air metering.
It seems to me, that by replacing the system with breather / catch tank, you are losing the 'flushing' effect.
If a catch tank with outlet to the inlet manifold was the simple answer, surely it would be cheaper for manufacturers to fit this than the PCV system... :shrug:
v-g
is an alien.
Mar 10, 2004
938
Nowhere near, i.e. Norway.
I was under the impression that you can fit a catch tank and keep the PCV system. :confused:
A catch tank should be as air-tight as the original tubes and hence it won't leak like a breather.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
yes you can. but you also risk the PCV sucking the oily fumes into the intake as the vacuum from the inlet manifold draws the oily fume thru and thru the one way valve.
each to their own.
preventing crank pressurisation and keep it closed loop is main reason/emissions method of achieving it.
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
ummmm this is interesting.....so wheres the best place to plumb in then because as long as the catch tank gets all the crap in the catch tank rather than in the TIP then this is good yea :think:
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
each to their own.
Bill, do you reckon that, by your method, the crankcase is 'flushed' sufficiently?
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
Flushed - no
ventillated so no crankcase pressure is created - yes
seperated from intake completely - yes
why flush? whats that actually doing?
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Flushed - no
I'm learning here - and I'll probably go ahead and fit mine just like yours. ;)
I was just in reading up on PCV systems, it seemed that the designed intention was to circulate air through the crankcase to clear water vapour, and blow-by gases that would otherwise eventually damage internal surfaces.
The point I was trying to make was without the introduction of fresh air to mix with the blow-by gases, you've perhaps got a more contaminated situation in the crankcase that is only being vented through excess pressure.
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
so in terms of fitting the catch tank one pipe on the tee thing that comes off the crank case the other pipe just to vent/breather
and what about this pcv valve...leave it in or out?
dos it realy mater about the pcv valve?
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
bill,
am i right in thinking yhats yours isnt connected to inlet mani? (the connection underneath?)
so you come stright frm rocker and crankcase to tank? with no other connections?
cheers
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
re-breathing crankcase pressure as opposed vent to atmos is for emissions... OE cant vent fumes due to regs so shove it down the intake again, and we see how oily that makes things.
the pcv valve brings some suction to the part of trailing throttle to suk , when its not being blown.
water btproduct of combustion is inevitable, which is why oil changes are important (not just sludging)
short journeys etc... create most dampage, PCV cant deal with those conditions.
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Cheers Bill. I just like to understand what I'm dispensing with. :D
As I understand it, pre-PCV, they tried to create a condition with a 'road tube' where the crankcase emissions would be sucked out by air motion past the backward facing tube. This was before emissions regs. They realised road tubes were causing all the smog.
9,335
South Wales
And a small pic of the amount of crap that my catch tank picked up after two months. All this would have either gone down the TIP/blown onto the MAF or been sucked into the inlet mani...
Not nice is it.
