Sep 4, 2012
719
Rainham essex
Just fitted my poly bushed dogbone mount. Would have been a 10 minute job if it wasn't for one of the bolts that hold it to the subframe snapping on me. So annoying can't even give it some welly to try it out invade the other one snaps.
Dozer360
mk1 Seat Leon 20v T
Jun 1, 2010
1,026
southampton
I had to drill mine a little bit till I could force a screwdriver in there and twist the bloody thing out, right pita and it was raining.
http://www.seatcupra.net/forums/showthread.php?t=358568
Gopher44
Fitted a new alternator pulley solving woeful power steering vibration.
Snapped a jaw off the open end of my spanner in the process. Modified tool to accept the ring end instead.
Found out how much of a pain in the arse it is to remove the third brake light from the spoiler.
RaviR50
2,756
Southampton
so over the last few days I've fitted a set of coilovers and looks a lot lower but still not as low as I want. Im knocking the anti roll bar at the min so im looking to get a bigger looped one with maybe some adjustable droplinks.
before
after :D
I think it also quite enjoys the taste of my garage driveway :p
Im hoping to get my hands on a set of 18" Merc AMG monoblock wheels then it will look quite a bit lower :)
Dozer360
mk1 Seat Leon 20v T
Jun 1, 2010
1,026
southampton
from my RR
did a bit more as its a bank holiday weekend
yesterday i started a little project
and i had some help from the GF
Did one more coat on the front this morning then moved on the the rear,
i think its ok to support the rear like this :shrug:
the rears were caked in years of dust
but nothing a dremel couldnt fix
then broke out my secret weapon, the GF
and had the rears done in no time
then noticed this pipe, couldn't think what it was at first, but now i think its the fuel overflow pipe from the drain port under the fuel flap
now i have to let them sit for 24 hours before i can drive the car [:@]:censored:
8bit
3,401
Aberdeen
Think I found and fixed my coolant leak yesterday. The pipe that the coolant temp sensor fits into was all wet, found my old non-green sensor in a wee box in the garage along with another retaining clip and o-ring so replaced the clip and ring on the car with those, dried it all up and went round the block. Doesn't seem to have leaked any more, will take it out for a proper run tonight and check it again on return.
stupot_1982
270
Flushed and replaced coolant, adjusted exhaust to look more flush, Stuck my 'L E O N' badge back on because i'm sick of the sight of super glue [:@]
Took split R off, old forge 007 back on
DuamoLCR
198
Brackley
Wallet is now a bit lighter after a set of plugs and coils goes better now tho so money well spent!
