What did you and your MK2 do today?
Sturtz1987
125
21
Ayrshire
I just got a pack of 25 screws and a pack of 25 of these washer to bite into the rubber and place them every 100mm. Didbt put any in middle as didbt want to pop through bumper. Tape was pretty strong but just wanted to be sure.
Sent from my D6603 using Tapatalk
Aug 6, 2009
969
cumbria
I had 2 new Michelin Pilot Super Sports fit on the front, the grip over the Pirelli P Zero's is amazing, hardly get any wheel spin in 3rd now and has loads more grip in the corners.
Dan FR
Meth addict. Stage 2+ Yo!
Nov 14, 2013
1,794
8
Caerdydd
How long!? :rofl:The ones I used were about 1/3 the length of those!
Sturtz1987
125
21
Ayrshire
There the sane size as oe trim panel screws, if it ok for manufacturer to use them I don't see what your all rolling about the floor laughing for the small screws probz won't be there this time next year
Dan FR
Nov 14, 2013
1,794
8
Caerdydd
You know you're going through the bumper plastic yeah? So at most, a quarter of that screw will be 'in' the plastic and the rest will be through and out the other side - making them much longer than needed?
FYI this isn't an OE trim panel. Don't get me wrong they will do the job fine but they're just overkill - especially as they are there to secure a thin strip of rubber on the off chance that the tape fails
And no Dan, didn't pre-drill.... when you use normal sized screws they go in easy enough by hand without needing a pilot hole :rofl:
natter07
Fitted some Heko Wind Deflectors in the rain. It was extremely easy. The hardest bit was getting the plastic paper stuff off the adhesive sections!
Jun 25, 2012
920
Gateshead
Spring clean,
Tell me,do you bleed
The weather halted play for a bit, I managed to get the Nanolex glaze/wax on, buffed n left for over an hour before applying a layer of Fusso dark light
Hawkers
334
58
Norwich, UK
Just installed my first mod today a evoms intake for my 2.0 TSI FR.
Darth vader under the bonnet with acceleration, nice whoosh when lifting off.
bigbadjay
1,670
26
North Manchester
Had oil and filter change, brake fluid change and MOT at Dave Cooks. Even got a stamp wey hey. Full geometry needed next week.
Going to DIY the rest of the service and coolant flush.
Edit- renewed insurance only £303
Daniel M
Blackbelts & Chickenheads
Apr 18, 2013
2,873
7
Middlesbrough
Had cambelt, water pump and front H&R springs fitted today along with new drop links and strut tops.
I'll put the rear springs on tomorrow after work. Cars nose down at the moment lol
Dan FR
Nov 14, 2013
1,794
8
Caerdydd
Gave up looking for true, reliable error-free sidelights and fitted some resistors to the wiring - No more fiddling with voltages through VCDS - they work as they should without errors :) Bloody awkward getting to the wiring with everything still in place though
AlexK1
545
Poole
That's what I ended up doing with mine, I'm using the cob led ones and fitted resistors to the wires as they would turn off after 4 seconds.
Sent from my SM-G925F using Tapatalk
richicupra
1,823
9
Ordered replacement locking module and a spline set, hopefully have four fully working doors again soon haha
