What did you and your MK2 do today?
Rob_Talisman
MKII CR FR 170 FL Stage 2
Sep 2, 2013
811
North East
want to change the fuel filter on mine, been on ECP and they list 4 different ones! how do you know which you actually need without removing my current one.??
connery-tdi
144
Essex
Check to see if your hoses are ok ok one might have popped off. Re price if it is turbo your looking at 1200-1500 at main dealer price with a new turbo. And prob no less than 700 8f you got a recon unit and went to an independent garage. all depends on what damage the turno has done to the engine etc as some send shards into engine , intercooler , hoses and everything so do thiusands of pounds worth of damage. Engine may just need a proper flush to ensure there are no tiny fragments of turbine, otherwise they will blow the new turbo when fitted.
Just seen this message after the best possible outcome! It was a pipe that had popped off! £15 at my local garage to find the fault and put it right! That's a relief!
Thanks.
STU3Y
1,271
Kent
Thanks.
Hopefully it wont pop off again but bare it in mind for a while when flooring it as sometimes they keep doing it
Rob_Talisman
Sep 2, 2013
811
North East
Ok chaps how do i know what part i need for fuel n pollen filter based off these pics.
olitaylor07
Badger Badger
Jul 15, 2012
2,422
West Yorkshire
Pollen filter is the 1KO 819 644 B and you will need the oil filter to see that. I presume the code on the code is the part number for the housing and not the filter
Aug 6, 2013
510
Thatcham, Berkshire
Rob, going by the pictures it looks the same as mine. I will pop out at lunch and see if my housing for the fuel filter is the same code, as the fuel filter was the correct one for me.
Rob_Talisman
Sep 2, 2013
811
North East
nice one mate appreciate that.
keep searching google with the numbers for that filter and the pollen filter and cant see any that match.........
Rob_Talisman
Sep 2, 2013
811
North East
Rob, checked my housing and its the same 3C0 127 400 C. The filter i linked to, should be the correct one unless someone else here says otherwise.
did you fit yours last night?
putting my detials in on the site gave me 3 different sizes, but if yours fits that housing then should be ok.
Aug 6, 2013
510
Thatcham, Berkshire
Fits. Even double checked with the one i was taking out. The rubber o-ring that it came with is the correct size as i haven't had any issues with diesel going past the o-ring like last time.
