want to change the fuel filter on mine, been on ECP and they list 4 different ones! how do you know which you actually need without removing my current one.??
Check to see if your hoses are ok ok one might have popped off. Re price if it is turbo your looking at 1200-1500 at main dealer price with a new turbo. And prob no less than 700 8f you got a recon unit and went to an independent garage. all depends on what damage the turno has done to the engine etc as some send shards into engine , intercooler , hoses and everything so do thiusands of pounds worth of damage. Engine may just need a proper flush to ensure there are no tiny fragments of turbine, otherwise they will blow the new turbo when fitted.
Just seen this message after the best possible outcome! It was a pipe that had popped off! £15 at my local garage to find the fault and put it right! That's a relief!
Thanks.
Thats the one i have got but yet to fit. Will let you know if i do it tonight.
Ooops , can't blame the car for that one Oli .
Fuel filter you mean
Bugger yeah is just the housing.
hit a brick or something on the A66, now have a lovely bulge in the sidewall - another £120 for a new tyre, not long replaced that one either...
Ok chaps how do i know what part i need for fuel n pollen filter based off these pics.
Rob, checked my housing and its the same 3C0 127 400 C. The filter i linked to, should be the correct one unless someone else here says otherwise.
