track car lcr
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
got price 2day for diffe, flywheels and clutch 2000 plus vat. so will be gettin that done in march. There not bad on the track r they i was surprised there was not much over takin me. just a shame couldnt get power down but that will all be sorted for next year. Have u had the 888 on the track yet. i was thinkin about buyin sum slick for next year.
if you have two sets of alloys go for slicks, but if you do go for slicks a baffled sump is a must. I'm running as much -ve camber as possible and -25mm ride with the offside +1mm. R888's are great so far but not been on the track. Seemed to fair well on the 1/4 mile too one warmed
scottslb1111
49
selby
yer gettin sump with anti roll bars over xmas. i dont know much about suspension set up so just going to cheat and take it sum where to set it up. But am takin note ofeverything u r all sayin though. there a guy on here that spotted me at mallory park and is ment to be putin sum pixs up so fingers crossed.
scottslb1111
49
selby
I have now got my every day car so things can start on the lcr. Am in the leeds area and was hopin people could give me a price for a quaife lsd fitted would be and a good place to get it done. I hopin to get in done b4 xmas while the car in off the road. I would atempt it but been told it a big job.
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
I've just bought a Autotech Wavetrac differential,
http://www.autotech.com/prod_drive_wavetracDiffs.htm
this is a ATB but with a bit of a difference.
I got mine for a good price and can point you in the direction of a few suppliers.
With this you'll need an 02M differential fitting kit
http://www.seatcupra.net/forums/showthread.php?t=241551
As for the gear box work there seems to be one main VAG guy who is on everyones lips when it comes to GB's and that's Vince at Stealth Racing.
http://www.stealthracing.co.uk/
From these guys your £399+ VAT for a gear box recondition and differential fitting. This might go up if there are any issues in the gear box.
The selector fork is a weak point in these boxes, ask them to drill out the rivet and replace this with a bolt/nut, cheers to Badger 5 Bill for this one:).
There are a few other companies that will give you good quotes for differentials, try
BackDraft Motorsport
INA Engineering
JBS (as above)
I have bought another gear box so can still use my car in the mean time. I'm just away to send my box down to Stealth in the next few weeks.
Let me know if you need any other information.
scottslb1111
49
selby
can any one tell me the benefits of havin the wavetrac diff over the quiffe diff as am unsure which one to go for and if i go for the quiffe diff i have to wait six weeks. so i need to order it soon. cheers, just fitted new brakes disc and pads today. big thanx to all that have help to far. I went for the 2 piece front and matchin rear.
Just need a trackday to test them on now.
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Did you read this?
This is all I know about the diffs until mine and my mates ones are fitted and tested.
These are currently getting fitted, testing soon:)
scottslb1111
49
selby
just looked at the site the 3d diagram helps alot. ive just read ur thread as it happens. I see ur cars comin on well. Let me know what u make of the diff.
scottslb1111
49
selby
cars booked in on friday for the wavetrac diff fitted and gettin baffled sump done at the same time. gettin all the work done at jbs.They seem to know what there on about.
Will hopefully have sum pics soon to put on here. Does anyone know where i can get sum 18" slicks from.
scottslb1111
49
selby
I've just orderd a turbo back decat today from awesomes group buy. Hopefully will be hear b4 the 18 may for when am going ta cadwell park trackday. Is any one on here going?
Next on my shoppin list is a rear anti roll bar. Should have that b4 we go to germany.
I'm well impressed with the new diff. What a differance its made. Just wanna say cheer to everyone that help so far.
scottslb1111
49
selby
i was told it would be up ta six weeks.It all depended on if blue flame had them all in stock. but that was after the group buy had finished. so it should be about three more weeks at the most.
I hopin there here before i go to germany.
scottslb1111
49
selby
need to order some new pads used them at cadwell park but also cooked my brakefluid. But noticed that the inner pad has worn alot more then the out side. Is this normal with the high temp that they get to. thinkin about get tarox track pads 601 I think they are called. this time doe s any one on here have them.
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
My inner pads do wear faster than my outers, but not substantially. Not too sure about tarox pads, but DS2500s and DS3000 pads are highly rated for use with the Brembo calipers. I am using RBF660 fluid at the minute to avoid brake fade on trackdays. Hope that helps :)
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
My brake pad wear has always been totally equal between the two pads, but it is very common for the inner to wear more than the outer.
I'm moving on from DS2500 to DS3000's. not because i don't like the DS2500 but just to see how good the braking can get
DannyC87
Mar 4, 2008
3,459
You thought about pagid rs2's Willie?
