Something a little Different....
Dale!
Robbie C's Personal Techy
Jan 11, 2011
193
Swindon
Had more time on him recently..
Got some more fuel bits through
Then I shot blasted the removable front panel
All primed up
Primed the front panel
Inlet runners primed
All painted
Connect under inlet for vacuum lines, air temp sensor and vacuum for servo
Inside inlet
New adapter for fuel rail need to machine down the new ones slightly
Next to mount the fuel pressure sensor and oil pressure sensor (Left fuel & Right Oil)
Route from regulator
Next was to modify the top of the tank, I epically ****ed my first one my trying to use weld on boss's....
So plan "B"
New part
Remove the connections
-6 through body connection with dowty washer top and bottom
Barbed connections for hoses inside tank
Fuel system mock finished
Then remove it all and fit carpet and cut away
Thats all for now
Dale!
Jan 11, 2011
193
Swindon
Got few more bits through
New exhaust manifold gasket and turbo to manifold gasket (Proper one to use as Vaux no longer sell this gasket....)
Got parts delivered from Owen developments. Turbo heat jacket, Worth a go as I want to get the Manifold Zircotec coated but I just don't have time before PVS I want it running early May in case teething problems..
Tial Q50 blow off valve in silver to match the external waste gate
Then I fitted the manifold and turbo with new nuts and fitted the turbo jacket
Cheeky shot inlet fitted now its sprayed
Got my custom Magnecor lead back for cylinder 1 which I had made at 64cm in length and the standard item is 54cm. Ignore the lead location its just for the mock up...
Dale!
Jan 11, 2011
193
Swindon
Update time again...
Since reading Nic Barnes issues with mocal oil cooler sandwich plate, I have since taken it back and will run standard plate for now, If I suffer with high oil temps I will change for billet plate with remote stat and go from there like most things its trial and error
Rude not to put it through the parts washer
New filter as always
All fitted
Few bits to finish fuel system off
Inside
and underneath
Now was to sort oil return from turbo, fenny used rubber hose which IMO wasn't for me! I had some spare fluro silicone hose so i adapted that....
Old vs new
Measuring up
Then heat wrapped and used aluminum heat wrap tape to finish it off. I will also do coolant pipe the last thing I want is a thermal event :(
Heat wrap matting
Also did the breather to be safe
Location for EGT and wide band (Not fitted correctly yet.) I have a spare boss now as I will no longer be using a separate wideband as its built in the motec
Rebuilding
Next onto air filter location.....
Either normal place
Or looped around down the inner wing
Picked up couple for sensors (Air temp, post rad temp and Map sensor) Also machined the rail adapters and oil pressure to block adapter
Where i'm currently upto
this thing looks like it could be a bit of an animal and it looks amazingly clean i dont even think vauxhall make them that clean.
i never thought that intake pipe would be man enough to go on the turbo clearly im wrong.
nice build though buddy been following this thread distantly.
joshy514
Fleet Air Arm by ability.
Mar 2, 2012
1,836
Gloucester
www.seatcupra.net
Soo much work on a corsa... i bet its worth it when your driving it though!? i cant believe how clean it is either!! you have done a fine job there. I'll have to give you a shout if i'm near swindon as i only live in gloucester, and occasionally drive through for work, would love to see it in person!
Dale!
Jan 11, 2011
193
Swindon
Awesome as always!
Videos definately needed once its done :)
Cheers, I have videos from other stages of the build which are here:
http://www.youtube.com/user/DSDevelopments1?feature=mhee
Cheers, I hope so but this year will be the lower spec version as I'm yet to get head done! Yer its reinforced by wire. Guy I know has one on his and runs 585 @ 1.9 bar on a GT35...
There has been alot of work and fun to say the least has been a total of 3 years now from standard to this stage and I do enjoy using it..... Yer sure be good to meet new people as seen in the thread it will be down Badger 5 for another power run as its a good comparison as its been RR'd there since day 1 and done god knows how many hours there!!
Dale!
Jan 11, 2011
193
Swindon
Awesome as usual Dale, how's Robbie doing with his?
Tom
Cheers Tom. Currently at Bill's having AEM water meth and mapping although I believe turbo may be getting old when I spoke to Bill last :( Think the plan is to pick it up this weekend
ben450
1,617
London
Excellent work as always mate I have so gotta get me some braided lines and anodized connectors I know they are not cheap but they sure look pretty [B)]
Dale!
Jan 11, 2011
193
Swindon
Had a little more time this evening...
Sorted out my coolant feed and return and heat wrapped like the oil return
Also did my turbo outlet joiner to boost pipe as this is close to the downpipe
All fitted
Dale!
Jan 11, 2011
193
Swindon
Been busy again first off was to design a sump plug to take new oil pressure temp sensor, as the temp sensor uses M12x1.5 trying to find adapter to M14x1.5 (sump plug) was hard enough and one that had enough "meat" to drill and tap a thread was impossible! So popped to Steve's (GWR Motorsport) and we designed this....
Adapters next to standard sump plug
Together
Also bought post radiator temp sensor housing to help monitoring....
Next I got to work with the Motec CDL3 dash, I want it to look as standard as possible, so it was time to start cutting and grinding, this is only a mock...
Rough placement with all standard dials removed and lugs
Done some more work to mount the shift lights but no pictures will update with more progress on dash soon
Mounted battery box
Dale!
Jan 11, 2011
193
Swindon
Been doing a few more bits over the weekend
Carried on this the dash, heres whats left on inside
Trial fitting with shift lights/warning lights
Got my bracket back from powder coating
Started to rebuild and cut light panel to allow room for coolant hose
Also shortened by vac hose for master cylinder
On the rebuild
Got my intercooler pipes "bead rolled"
All on and mock fitting Tial BOF
Then got these made, rose jointed lower arms and track control arms (note the TCA are placed the wrong way around here)
Lower arm
All fitted, I have kept from spacer plates as it gives me clearance from intercooler piping. Lower ball joint spaces don't fit but this isn't an issue as the lower arms clear with F28 fitted due to different pick up points. The chassis was drilled for 1/2" bolts for lower arm which was fun with engine in. In the end I removed the engine mount and lifted either side to make sure the chassis was drill straight! Over all very happy with the kit and quality of welds!
Fitted post radiator coolant temp sensor
Fitted air temp sensor in the oil cooler housing
Getting there slowely
Coil fitted with leads
All for now :)
Dale!
Jan 11, 2011
193
Swindon
Looks awesome
I wish my corsa let made it this far :(
Cheers, Yer not many get to this level or have the "whole" package like this IMO
Little update nothing great....
Got some new shorter lower arm to ball joint bolts as I had spacers before
Had alittle play with adjustment of caster....
Wheel and wing placed on
Then got my new Big block hub flanges (Not conversion hubs) and knuckles back...
Knuckles with part grinded off for clearance for Alcon brakes
These will be powder coated now
Then I carried on with Dash mock...
Feel Wet lay carbon 1mm thick (Not crapped "carbon wrap")
Cut out to go into housing
Cut out for dash
Front face on with the motec shift lights/warning lights at top can only just see
