Had more time on him recently..
Got some more fuel bits through
Then I shot blasted the removable front panel
All primed up
Primed the front panel
Inlet runners primed
All painted
Connect under inlet for vacuum lines, air temp sensor and vacuum for servo
Inside inlet
New adapter for fuel rail need to machine down the new ones slightly
Next to mount the fuel pressure sensor and oil pressure sensor (Left fuel & Right Oil)
Route from regulator
Next was to modify the top of the tank, I epically ****ed my first one my trying to use weld on boss's....
So plan "B"
New part
Remove the connections
-6 through body connection with dowty washer top and bottom
Barbed connections for hoses inside tank
Fuel system mock finished
Then remove it all and fit carpet and cut away
Thats all for now
All primed up
All painted
Inside inlet
So plan "B"
New part
Thats all for now
