Show Us Your Engine Bay Pics
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
I know what you mean, might look into it and do some measuring and see if the filter fits along side the engine cover.
Loony R
Quattro ist fur sissies
Nov 23, 2007
244
Rossendale
Well its certainly different :D, I'm liking the heat sheild, its very like the jabba one but it looks sweet any pics of it off the car so us peeps can see whats invloved in it.
P.S that bend in the silicon pipe from the filter to the MAF ain't gonna help with you airflow readings.
Hi matey thanks for the comment.
Here's a thread to how I made the heat shield.
http://www.seatcupra.net/forums/showthread.php?t=263702
How come the 45degree bend in the hose after the filter could cause problems? its not kinked its a proper bend.
jake
I AV MOSTLY BEEN BEATING
Feb 2, 2003
2,666
rochdale
its a modified s3 cover, there £75 from audi, and like hens teethe to find used, you also need the washer bottle off the s3 5l version
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
It has been suggested and recommended by most companies that tune these engines that a bend in the tubing to the MAF can cause the MAF to misread the airflow, if your MAF misreads airflow it can lead to other problems like fueling being off.
I can see the logic in i guess. if you think about it the bend with cause the airflow to go to the outer part of the bend and not be read correctly.
P.S thanks for the info on the heat shield
