SAMS BLACK LCR GT2871 build. THE END :( !!!
Feb 14, 2012
684
Slough
boost is displayed on the dyno plots 25psi, sustained. For all your airflow Junkies, 286g/s of logged airflow on the dyno. :)
egts max during power run in 5th 895'c
duty cycle max is 71%.... We are fuel limited, but its not liking much timing at all >5krpm
smallport head, no wmi, Both of which are on Sams "to do" list I think.
Cams, also likely... given the great results posted on FB from n/a cams tested on k04 car
Its not max'd out currently.. but is rapid on the road.
I have dialed in some more 2nd gear boost which I need to check today. The gear based boost is switchable so all of the 25psi can be made available by simple pedal sequence pressing.. (on the fly, if I set it that way, which I dont as normal)
Largeport should unlock some top end timing potential as will wmi..
Given egts have'nt gone daft as yet on this level of boost and low relative timing, there would seem to be scope for more.. However, the 550's are 96%IDC now whilst trying to achieve the fuel requests. Fuel pump replace first and review me thinks.
Nearly there I think. :)
So the egt's are acceptable compared to a hybrid, boost levels are sensible and sustained and all with a smallport head and no meth.
Seems that this is the way to go in future. Really looking forward to final results although I would be more than happy with how it sits at the moment.
Top work Bill and Sam I'm sure you can't wait to have a drive.
Sc22
206
are you still on standard suspension or coilovers? havnt read all the thread to see if u have changed lol
sambryant
RoadRunner meep meep
Mar 26, 2009
4,848
Bristol
Seal_LCR
2,601
Redditch
Dam you bill I was just about to add that video :), hooked it up to my surround sound. I loved it mrs wasn't too impressed :funk:
Its on coilovers but will change them for shocks and springs.
What coil overs have you got and could you let me know when there off and a price :D
Oct 21, 2006
1,226
Norfolk
Simply awesome Sam. I can't imagine how this must feel to drive on the road... Epic I should imagine... Hope all goes well with collecting it today. Drive safe and enjoy it :)
