Well I have finished setting up the final tweaks (I think!), TBH the SPS unit wasn't much use as I am beyond the max settings! Boost 9 and timing 9 saw zero timing pull, so I added 3 degrees of timing in Unisettings, then I started to get small amounts of pull, so I have stopped there. Fuelling seems to have settled around the -10% mark in the second field of the fuel trims. Boost is set to 1.6 BAR.
On a full power run the outside temp was 20 degrees, intake temp was 24 degrees at full boost, so the Forge intercooler and the water methanol injection are both doing great jobs!
Car pulls hard, spools quick and holds the power as far as I dare go, acceleration is quick, strong sustained push in the back, minimal wheelspin - so I feel I have the optimal setup now and I am more than happy with it.
Just need to get it on the dyno now to see what it's making.
