Nothing bro, I called R Techhhhh but they busy as hell!, they said it's £40 per hour etc etc and I have to drop my car there and will take 2-3 days?!! they have qood reputation I know but the
problem is, I have to take my mrs there with me to bring me back home) and then wait untill the weekend to pick the car back up!?
I've been recommended this place in Coventry / Warwickshire called 'Stealth Racing' they have rolling road, and a smoke boost leak test machine, booked in for the 18th, fingers crossed
It's driving me insane bro, how is this even possible, boost leak or not, i've changed everything you can
Is there ever a point on these cars where you have to consider the ECU itself is at fault?
Just thinking out loud.
This has crossed my mind............
Yeah could well be, mates wouldn't start till he got his repaired.
What exactly happened to your mates Lee and what did they actually repair? the EPROM data on the same ECU or replaced the ECU?
very unlikely its possible but never heard of these ecu's failing in my experience on the 110 tdi yeah but not 1.8t, defo don't think its boost leak that causing your constant limp mode, i would say 4 area's to look out actuator , n75 and n249 , and dv defo think its to do with either one of them
n75 has been replaced with a brand new one
n249 has been restored to it's original set-up with up-rated hoses
DV, i've tried both my standard DV and the Forge 007p (6 months old)
Actuator is probably the next thing I will look at but I wouldn't know where to start and what to look for, the hoses as you now know has already been changed, well half way point.
I mainly asked because it would appear that Mo has changed everything you mention, plus most people who have issues with any of those components rarely get constant limp mode 100% of the time.
And that's the point i'm trying to make!!!! but no one is listening to me, they keep telling me to check the same boring old parts that go on these cars over and over again which I have replaced with brand new OE parts no expense spared!
i would offer for mo to try my ecu but immobiliser would not alloy it to start
Thanks bro....... read on though
Full vag com allows ecu swapping, simples.
I have VCDS Fully Registered Latest Version will this do the trick? I have the following software and cables:
VCDS
VAG K+CAN Commander
KWP2000+
Galleto 1260
Only one I don't have is VAG Tacho
well if thats the case my car is off the road so you can try my ecu mo if that helps
Thanks again bro
Mates ecu failed on his ibza 1.8T but was down to mapper not knowing what he was doing and ended up doing something the software and then it wouldn't go back
easy to see if your leaking is to log the boost
I know I keep saying it but think you should
or ask this place to go through the logging with you when you get it smoke tested
I'll try my best to get some logs, persuade the mrs, the wee one keeps crying when his away from him mom! so it's a bit hard
OK, thanks for all you input guy's, sooner or later after changing all the commons parts, I knew 'ECU' would pop up somewhere, so ..... I got a good deal on a ECU from a facelift mk1 cupra with white dial clocks and imobiliser chip thingy, so plug and play really
I mainly bought it to mess around with to learn etc but it looks like it might come in handy! BUT I don't want to go down that route yet, if there is ANYTHING else I could check or do, I'm willing to do it , man I've learnt **** loads about these cars over these 2 weeks.
