I only only bolted the pipe going to the dump valve, originally.
I haven't removed the N249 though.
also i noticed on your map sensor does it have a gasket between it and the metal pipe? cause i cant see plastic and metal making a good seal.
Does the cooler its self have a leak? Pressure test the intercooler.
Also have you checked the hose from the n75 to actuator.
Is there ever a point on these cars where you have to consider the ECU itself is at fault?
Just thinking out loud.
