Refurbing Your Brembos: For Dummies
CHRIS200
Powered by Seat Sport
Oct 4, 2003
388
Fleet, Hants
Yeah the Hamerite does take a while to dry, you need to leave it a week before you apply the stickers and laquer to them.
Painting is really easy, as everyone says it's in the prep. I used a very aberisave wet n' dry sand paper to get most of the paint off an dthen used a very fine paper to finished.
I then de-greased and washed with warm water. Got the heat gun on to dry all the water and heat up the metal a bit. I then applied 6-8 coats of paint making sure I got every square cm at 15min intervalls and then left for a week before I applied the Brembo stickers and laquer.
Very easy to do just time consuming but very pleasing results. I used about a can and a half of Hamerite from Halfords. Think it was £6.99 per can.
I did think about painting them black, silver or yellow but decided to go with the red in the end.
cupralove
Rear Brembos
Just wanted to join in and say this thread was brilliant and your Brembos look wicked!!!! You've inspired me to do the same with mine. But I would be more inclined to try the rear ones first as they look really dull.....
But I can't find any pics from anyone thats done the rear brembos, Can anyone help??????
Cheers guys![B)]
Ruddmeister
Everything in Moderation
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
Cheers guys![B)]
Doing the fronts is a piece of cake
The rear ones are not Brembo's they are VAG units
cupralove
Cheers for that Ruddmeister! Still learning....Ony pick up my LCR 2 weeks ago.
Any tips on refurbing them then?
m.r.davies
God's Property
Jun 13, 2006
608
Cardiff
Cheers guys![B)]
Thanks dude
Yeah rears will be the same as the fronts, going to give it a go when the rain stops.
I'll be posting up some pics when i get it done, the fronts are looking spanking and the rears are really letting the car down
andycupra
status subject to change
do we need to organise some brembo stickers as a group?
i can see a few people will be needing them if not now soon...
scotty, for changing colour id say at the very least you would need to remove the calipers / pads /bolts. should be too difficult though.
you going yellow?
cupra r rob
165
Would'nt useing a normal lacquer cause it to peal again with the temperature? Going to do mine this weekend with hycote high temperature lacquer and see how that works.
Skorchio
600 Miles to a tank :)
Jan 23, 2007
1,570
Nr Milton Keynes
Got my LCR yesterday. Just taken off all the wheels and cleaned them inside and out and all the calipers. they look loverly. cleaned the spair wheel too.. Sad? I think so :D
Im thinking about spraying my rear onces up gloss red. Then some lacker!!
