Removed the EGR valve for a quick clean, removed the rocker cover to check the condition of camshaft lobes & lifters - thank the wee man above that they looked OK
Refitted rocker cover with new gasket (torqued to 10Nm). Refitted the EGR valve and pipework.
Dropped the old sump off and removed the oil pick-up pipe, replaced it with new pipe.
Drew around old sump on cardboard to see if there is a difference with the new sump then refitted the old sump with a couple of bolts.
Turns out that there are a couple of areas need fettling back so dressed back with Dremmel.
Need to get oil next ………
