contd............
So I have more pics of the illuminated air vent install.
Removing the dash end covers is easy, just prise away and pull free - they are held in with 3 metal tangs:
I then removed the glovebox by removing the following - at the bottom right of glovebox there is 1 Torx screw:
Open glovebox and remove 4 Torx screws from top:
Undo 2 Torx screws from left side of dash (as in the 1st photo above), then the glovebox drops down. Unplug the 2 connectors.
I removed the fuse assembly, 2 Torx screws (to make it easier to install loom):
I didn't take any pics of removing my radio as there are oodles of pics/guides on this and other forums
. Connecting the wires to the loom through here was a bit fiddley
Remember to have your radio code available prior to disconnecting radio
This pic shows the wires going through hole I punched in the air ducting:
and the wires connected to loom:
I used a splice terminal to connect the live (Red) to the light switch dimmer cable:
I connected the Black to an earth point behind the fuses.
I made sure the lights were working on the vents
, then fitted everything back into place:
Hope this helps anyone wanting to give this a go.
![Cool [B)] [B)]](/forums/styles/seatcupra/oldforumsmileys/shades.gif)
