Pillar Gauge Pod
D1andonlyantman
410
I finish work in half hour and am gonna go get stuck in :) early start tomorrow too so I can hopefully get the other bits done too
D1andonlyantman
410
Still can't get the god damned wipers off and also that clear bit of plastic sort of inbetween the wipers on the panel just pretty much turned to dust. Is that bad?
D1andonlyantman
410
Right, I'm about to wire it in. Should I go into one of the wires that goes into the headlight control panel? Any idea which one?
D1andonlyantman
410
Adam, I've connected both the gauges to the red and black power lead from the headlight control panel but one of them is dim. Is that going to be because the other one is closer to the power source and drawing too much power?
D1andonlyantman
410
Jobs a good'n. A wire had come loose when my mate stuck the fusebox back on. Didn't have time to have a good look at where the oil sender goes but I've got the gauge all fitted and the wire to the sender in the bay. I'm happy with the look :) I'll get the sender done tomorrow if possible but if I need an adapter I'll sort it next weekend
D1andonlyantman
410
It weren't too bad to be honest. This was my first time doing proper electrics and I made the amateur mistake of turning on the ignition and looking for a live wire to jump into without testing it with the ignition off. You can guess what happened.... I won't make a mistake like that again! Glad you told me where to drill through or I never would have been brave enough to do it, so nice one for the help. One more quick thing if you don't mind.... :) Can I get to the oil pump to stick on the sender from the top or should I get it on the ramp?
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
I'm not 100% sure where it is but I think it's on top of the filter housing? Without having a look I'm not sure and I'm not with my car to check at the moment.
If you can't sort it I would say the sandwich plate is the easiest option.
D1andonlyantman
410
The bloody hose popped off the t-piece and I guess stopped the dv operating and the turbo made a pretty nasty noise. Sounded like a flutter valve in pain.... I'm not sure if the sound was the turbo forcing up the piston or it was the actual turbo really not happy, but it didn't sound good... I reattached the hose and superglued it so it won't come off again, and the turbo still boosts to the same psi as before and sounds fine, but I'm guessing whatever that noise was, it wasn't good.....
