OBDEleven Formentor - See below for working ones
Mares
16
Serbia
Tnx, I figured out how to do long coding with OBD11.
I managed to do some codings/modifications mostly from the list of German guy, but I am unable to modify 5F module, after long press of the green check mark I get the message something went wrong and no change is done. Anyone experience similar?
Tell
Feels like SFD. There was SFD 1 then 2. Not sure where we are with the rollout of that.... did a Google for you
If it's 2024/5 car then you might have fallen into SFD2 issues if it's prior then it's not that, that was sorted out. Basically VAG license the software to the coding companies then get income of it. If it's SFD2 then it's a teething issue yet to be fixed... I guess.
Mares
16
Serbia
Although it was a brand new car purchased last month (was kept on stock), it is pre-fl model, built date september 2023.
I did not have problems with changes in other modules.
Sent from my RMX2170 using Tapatalk
the_winner
39
10
33
Athens,Greece
i have almost complete to enable trailer assist at Cupra Formentor Hybrid MY2022 with stock tow hitch and no 360 view , it recognize the trailer it shows at the dash to enable the trailer assist from the infotainment but i can't code the infotainment because is SFD :(
Tell
The Vag crown jewels are in the infotainment unit protected by SFD and they might have decided to release protection on other SFD units via a compliant app like Obdeleven whilst still protecting the infotainment unit from user mods. So you probably need to keep an eye on the Obdeleven board. SFD 1 and 2. Fortune my car is pre SFD.
Reddit one here on SFD2
https://www.reddit.com/r/Golf_R/comments/1eid51e
Let others read through that as to whether there are SFD 2 gems in that.
That will tell you what is open.
Formentor always had SFD 1 it's what SFD 2 may limit and 2024 models. The link is suppose to tell you what is unlocked whilst the Reddit link is worth a read.
The Reddit link is telling you to do this first which unlocks SFD:
I'm sure I'll be told whether this is useful or not.
Mares
16
Serbia
It seems I mixed up some things when writing my complain about unavailability to modify 5F module. Actually modifications under this module are working fine, the one I can not change is actually STG13 (to diasble prevention of overtaking on the right side) - long coding - overtaking right prevenion - disabled -> error message appears like something went wrog. Any solution on this?
I have some qustions whihc refer to coding from German guy list:
- Point 2: does modification under ACC to acivate classic cruise control eliminates operation of ACC, or it will be possible to choose between ACC and classic cruise control when driving? I would not like to turn off ACC in favor of classic cruise control.
- Point 21: parking aid - automatic activation when driving slowly forward: This coding switches the PDC sensors on when driving forward slowly, but in most cases this is how it is set straight from the factory! Experimental!
STG 76 ÿ Long coding ÿ Byte 03 ÿ Activate bit 4 –
I get a message "function not available"
- Point 26: I activated driving school mode but not sure where to look for it in the infotainment? I mean, this is not important option for me but just wanted to check how it works.
- Point 43: I do not understand this mod, is it related to voice control of AC?
- Point 51: acknowledgement tone via horn and flashing (without DWA): I did modifiation but not wokring for my car, forgot to save factory setting before mod so I am now unsure if I turned back everything according factory settings (because some lines were already active compared to instructons give. If somebody could give extract of factory settings for this I would appreciate.
- Point 63: START/STOP system: anybody tried it, is it safe to use it (modify)? I still have not enough time to investigate proper option to turn off permanently SS system on Formentor, would appreciate somebody share information n this matter.
Reactions: Tell
Mar 11, 2024
Disable trunk beep with code is:
1. Control unit 6D
2. Security Access-code 12345
3. Adaptation
4. Ausstattungen aktivierien
5. Tone Sensor to "not active"
I tested it my formentor from 2021 and it's working.
Reactions: Tell
Tell
They like to take the beep off in gated communities so you can get back late without disturbing everyone. The beep with the door open... if it does that, is another one. I've seen people seeking answers on that. That one might be like stop / start more tricky to stop.
The tailgate can hit you if you have a pet and it replicates the foot underneath process. Not been hit but have heard the beeping start off with the feline charging left to right underneath. What caused that and ball of fluff runs out the other side.
flatbone
19
Hi. Anybody knows if it's possible to obtain only the top taillight LED bar illuminated, (without the lower signaling segments) through obdeleven long coding?
I've seen online that some people have done it but I'm not sure how.
Mares
16
Serbia
Any option to turn off warning message to put the hands on the steering wheel? Also, to turn off time-to-take-a-break message?
tommyfulf
35
I tested it. And it works!
One annoying thing tho. The "Place hand on steering wheel" warning came quite fast. And even if I had the hands on the wheel. It sometimes came up.
Maybe some other setting for this to be less prone. So I reverted back to Stock. I need to investigate further. Or if anyone got an idea.
Other settings I did was to turn of the annoying auto lock over 15Kph. I do not live in a car hijack country.
Well anyway. First coding on my new car. Great success I believe.
Did you ever manage to get this to work better?
Waiting for my OBD11 Pro to come and looking at options to change and one thing I want is travel assist, debating getting a capacitor steering wheel and coding that but if this option works as well i may save myself a steering wheel change
tommyfulf
35
Hello
I have a 2022 model 1.5 tsi Dsg formentor
Standard Equipmant :
Cupra Car Safety (Adaptative Cruise Control System + Lane Assist System + Park Assist System + Rear Cross Traffic Alert System + Lane departure Warning System + Door Opening Warning System + Front Assist System
These are my standard hardwares. Can I activate Travel assist and emergency assist? I ordered capacitive steering. See if anyone can help with the issue.
Did you get travel assist to work i have the same formentor as you had 2021 though and am looking to get travel assist retrofit/code. Think it's just the upgraded steering wheel and code.
Tell
I do suggest you eyeball this thread. It's what SFD2 allows you to do which was put in with 2024 models
It's still a live subject and I see trusty DV52 is posting towards the end of that. Suspect it's a suck it and see and a moving target.
cairus
1,143
405
If you want to do a lot of work on the vehicle yourself, I would currently stay away from UNECE vehicles. And I already have better equipment.
Reactions: tracktoy
tracktoy
716
558
Afraid OBD11 in my opinion is not worth the money till they and VAG sort out the interface for the newer models.
I am also fairly sure that VAG had put a lot of limitations on what users can do on the newer models as the business model is all about selling features via VAG shop.
Interestingly OBD11 have today released a new version that also works with ELM327 Dongle for basic scanning and they have not updated the VAG App in some time (in terms of new features or fixing the large backlog of bugs) it feels like they are more interested in the one click app model for BMW/TOYOTA (And there are more to come)
Tell
Work in progress... but if you haven't got a 2024 model then it isn't. Balancing act of trying to stop people getting features they haven't paid for, charging dongle manufacturers a fee / income stream for mods and keeping within European safety / security standards. Pre 2024 it's fine. It could be a re-run of SFD 5 years on.
