OBDEleven Formentor - See below for working ones
Mares
9
Tnx, I figured out how to do long coding with OBD11.
I managed to do some codings/modifications mostly from the list of German guy, but I am unable to modify 5F module, after long press of the green check mark I get the message something went wrong and no change is done. Anyone experience similar?
Tell
Feels like SFD. There was SFD 1 then 2. Not sure where we are with the rollout of that.... did a Google for you
If it's 2024/5 car then you might have fallen into SFD2 issues if it's prior then it's not that, that was sorted out. Basically VAG license the software to the coding companies then get income of it. If it's SFD2 then it's a teething issue yet to be fixed... I guess.
Mares
9
Although it was a brand new car purchased last month (was kept on stock), it is pre-fl model, built date september 2023.
I did not have problems with changes in other modules.
Sent from my RMX2170 using Tapatalk
the_winner
8
Athens,Greece
i have almost complete to enable trailer assist at Cupra Formentor Hybrid MY2022 with stock tow hitch and no 360 view , it recognize the trailer it shows at the dash to enable the trailer assist from the infotainment but i can't code the infotainment because is SFD :(
Tell
The Vag crown jewels are in the infotainment unit protected by SFD and they might have decided to release protection on other SFD units via a compliant app like Obdeleven whilst still protecting the infotainment unit from user mods. So you probably need to keep an eye on the Obdeleven board. SFD 1 and 2. Fortune my car is pre SFD.
Reddit one here on SFD2
https://www.reddit.com/r/Golf_R/comments/1eid51e
Let others read through that as to whether there are SFD 2 gems in that.
That will tell you what is open.
Formentor always had SFD 1 it's what SFD 2 may limit and 2024 models. The link is suppose to tell you what is unlocked whilst the Reddit link is worth a read.
The Reddit link is telling you to do this first which unlocks SFD:
I'm sure I'll be told whether this is useful or not.
Mares
9
It seems I mixed up some things when writing my complain about unavailability to modify 5F module. Actually modifications under this module are working fine, the one I can not change is actually STG13 (to diasble prevention of overtaking on the right side) - long coding - overtaking right prevenion - disabled -> error message appears like something went wrog. Any solution on this?
I have some qustions whihc refer to coding from German guy list:
- Point 2: does modification under ACC to acivate classic cruise control eliminates operation of ACC, or it will be possible to choose between ACC and classic cruise control when driving? I would not like to turn off ACC in favor of classic cruise control.
- Point 21: parking aid - automatic activation when driving slowly forward: This coding switches the PDC sensors on when driving forward slowly, but in most cases this is how it is set straight from the factory! Experimental!
STG 76 ÿ Long coding ÿ Byte 03 ÿ Activate bit 4 –
I get a message "function not available"
- Point 26: I activated driving school mode but not sure where to look for it in the infotainment? I mean, this is not important option for me but just wanted to check how it works.
- Point 43: I do not understand this mod, is it related to voice control of AC?
- Point 51: acknowledgement tone via horn and flashing (without DWA): I did modifiation but not wokring for my car, forgot to save factory setting before mod so I am now unsure if I turned back everything according factory settings (because some lines were already active compared to instructons give. If somebody could give extract of factory settings for this I would appreciate.
- Point 63: START/STOP system: anybody tried it, is it safe to use it (modify)? I still have not enough time to investigate proper option to turn off permanently SS system on Formentor, would appreciate somebody share information n this matter.
Reactions: Tell
