OBD Modifications
Antera
333
126
Breda, Netherlands
Www.vcds-coding.nl
If your CarPlay work by wire, it's 99% chances that it works wirelessly. If they just put all the modules, you can turn it on via OBD.
Please follow my instructions: https://www.seatcupra.net/forums/th...le-disabled-in-my-country.465808/post-4994645
Not right. Most of firmware 16xx and Some 17xx verslons doesn.t support wireless and put in code but didnt work. Missing Some kind of software i tink. On golf the cars who are updated to 18xx have wireless after the update.
Widil
108
22
Have a question for people with travel assist, is there a way to switch automatically to the TA view on dashboard when you activate it ?
Widil
108
22
Not possible and why should you. You can see it active at the icon in je aid
Actually, with the acc button on non capacitive steering wheel, you automatically switch to this view, so there's nothing making it impossible.
Also, why should'nt I ? When set on highway at 130km/h, I dont care about my cupra view. The travel assist view is more interesting.
Antera
333
126
Breda, Netherlands
Www.vcds-coding.nl
That is you opinion. Other people want something else.
Jan 14, 2022
9
After coding some of the OBD modifications from this thread on my Leon e-Hybrid, I noticed my energy consumption quite a lot higher than usual. From an average of 14-15Kwh/100km to around 19-20Kwh/100km. Any ideas what might have caused this? My electric range went down quite noticeably.
simoammi
26
19
Hello, what encodings did you do? I recommend that you turn them off one at a time and see if it improves, then share the result. We live on tests, no one is certain, you are the first to notice such an evolution. Help us improve, thanks
simoammi
26
19
Does anyone know the code to make the fog lights come on during DRL? There is now an app for it
I'm looking for it, but nobody here goes to help the community? even if I don't see the usefulness I try the coding to avoid using credits to people.
Indeed if you want to try, to activate the moving videos can someone try to see if these changes are enough?
Control unit 5F
adaptation
NHTSA PROPERTIES
disable all the voices that write about android auto
Reactions: whataboutthis
connortickle
7
Manchester
Hi, has anyone had any luck in activating the rain closing for the pan roof? Read a lot about this feature online, but not found much about activating it on the MK4’s?
Manage to activate cupra display, but having some trouble activating G meter and accelerometer, if anyone can advise on this as well I would be buzzing!
simoammi
26
19
Hi, for the roof that closes when it rains I can't help you by not having it, while for the rest you ask you have to follow these codes:
- Select Control Unit 17
- Select Vehicle variant - this is mandatory otherwise the subsequent encodings will not work
- Set to Derivative 6 (For Sporturer)
- Set to Derivative 4 (For Hachback)
- Select Adaptation
- Select Configuration of displayable contents
- Select Engine power
- Set to Active
- Select Engine torque
- Set to Active
- Select G-meter
- Set to Active
Aug 5, 2021
28
Hello, some pictures of the travel assistant show gray vehicles instead of blue vehicles. Is there a way to change the coding? I find the color selection with the gray vehicles more pleasant.
connortickle
7
Manchester
- Select Adaptation
- Set to Active
- Set to Active
- Select G-meter
- Set to Active
Thanks a lot mate this helped massively!
Im still yet to find info on the rain closing… it seemed relatively easy with the MK3, but not the same with the MK4’s :(
