OBD II Wireless Devices and Apps
Geordie2001
73
Hi All,
So i'm looking at getting a fault code reader.. what is the latest suggestions?
I have an iphone and a laptop. Suggestions?
shnazzle
Glass-Half-Full Member
Sep 9, 2011
3,480
Northumberland
Hi All,
For iPhone you only real option is DashCommand and a wifi OBD2dongle off eBay. Or a Kiwi system...same difference. Much pricier.
I used the DashCommand logs in ScanXL, the PC software made by the same people (Palmers).
Still waiting for someone to come up with a way to read more PIDs from Leons because as it stand, the amount of things you can read is a bit poor
Geordie2001
73
So you don't recommend me getting one then for the iPhone?
I only want to read fault codes.
bubbles1
Nurburgring Lover
Dec 28, 2008
490
Llandudno
Just ordered a ELM 327 OBD 2 WiFi thing from amazon and bought the Dash Command for my iPhone for £6.99.
My question is doese the ELM 327 drain the battery if left plugged in?
Dont want to mess around pulling the storage tray from dash every time I use it.
Cheers!
Mac
211
TM. RO
www.racingparts.ro
just try to find it with wifi after you remove the key from contact
if you cant find it , it's OFF :)
havent tried yet
cant get the dashcommand to show boost on my car
bubbles1
Nurburgring Lover
Dec 28, 2008
490
Llandudno
Will do that! Thanks for quick reply!'
For a few £££ thought I'd give this gizzmo a try but not sure if its a bit of a gimmick lol!
Mac
211
TM. RO
www.racingparts.ro
i got torque pro to work on wifi:)
cleared the Egr error
the device plugged into the obd port will be on, so will have to unplug it every time
i guess the current consumption is so low that can remain plugged for a few days without problems.
if one uses the car everyday shouldn't be a problem because battery get's charged in a few minutes to full :)
Hi all,
I'm just wondering if anyone out there has managed to get the Android Torque Pro app to show accurate turbo boost readings on a mk2 Leon Cupra. I can't get the app to show positive boost pressure, (although it does show vacuum ok). The gauge reaches 0 or there abouts but nothing further.
I have set the correct vehicle/displacement etc in settings & have set to read MAF rather than MAP (as advised by the app maker), but still no positive reading?
I know the turbo is working. Any advice would be appreciated.
Also can anyone confirm what the boost should be on a standard Leon Cupra mk2 and also with a stage 1?
I had email off the Torque app developer who said the app reads from the MAF sensor rather than MAP and that you have to manually adjust this in settings. It made no difference though as still not reading any boost?
Any suggestions anybody?
Also wondering what the boost pressure should be on standard 2009 Leon Cupra & after stage 1.
I know in my Mk1 LCR (a long time ago when Torque first came out) I had to manually adjust the boost reading by 14.7PSI (ie atmospheric pressure) it then read the correct boost all day long. Was quite good for seeing boost spikes etc.
not used it for a while since I moved to apple - the Wifi dongles were all really expensive back then, they seem to have come down in price a lot!
bubbles1
Nurburgring Lover
Dec 28, 2008
490
Llandudno
Ok I have my OBD2 reader and the dash command app but can't get it to work . It connects up to my iPhone ok but nothing works on the screen apart from the battery voltage dial. ??
Anyone have an idea ?
Mac
211
TM. RO
www.racingparts.ro
last nite we took the Cupra for a speed test and we had problems with the connection, the ELM keep disconnecting from the phone, i dont know why, we only did connect to it for a few minutes then connection dropped
on my FR instead works for hours :)
in dash command i had wifi connect to the elm then to put IP 198.168.0.10 to make the program work
otherwise it doesnt see the elm
after that it works, and now asks me to pay it :)
Benzy
1,214
I have the same one as this. From what I can tell it won't work on an iPhone. U need android mate
