ND-Photo.nl 's - Seat Leon ST Cupra 280
TripleBob
351
252
Don’t know whether you’ve found the same with yours also being at estate, but when I’m “making progress” the chassis flex at the rear is ridiculous - I can look in my rear view mirror and literally see the back end twist out of square!
I considered a K brace, but as I regularly put the back seats down I don’t want the hassle of having to remove it every time I need to use the full load space. So I’ve just picked up one of these bad boys:
nd-photo.nl
4,222
360
The Netherlands
youtube.com
When I bough the car, it was no secret that the brakes needed to be done. My last cars have had Brembo discs but for the Cupra I wanted to try another brand. Friends told me to go for Zimmermann, so I did :yes:
Was able to source 4 discs + brake pads for 413 euro including shipment. That is a steal! Unfortunately, the rear brake pads did not fit, so I had to source another brake pad set.
AP1GczM224vWVkVY0T5CVRyXMRHNmkoWd_pyd2jvhEd1jNVpiavXVFAvnny3SeZJINP7ADsRdva3VFtSA-SSbBqm5vn7lUGRcTlh_ukAmpJOnA4D6Fo2lfDbnrNzbow_Qku3e-Ov47sFUZZ_MWGepJf4jLziKQ=w1920-h1080-s-no-gm
This is how the front discs were looking
AP1GczMfUlHWSd6o24H8WtYjLNbrxkW6ZYFcQAqTYYPjKmy0yKttSaibxKOdxwFVJ4oJrvANvbbfkWsChRn19_mxMQfTLQWHtlemDSRWuhxlj0wgzk0U1W8IpSlaNX-rMtTqLsD1zQS969Y-L_x1d2ajrl7REQ=w1920-h1080-s-no-gm
The amount of rust in the disc was alarming
AP1GczObYXeNPMe5729YwFHW-pRPOm4GdesGcVk7hzdu70WfuR3g6JA5X0xhvTHqyw7yd91SKdK4MyvLcd35N7wrS73tRcDiUMCM6X_dMdwp0DNuaP5cjyGygND3XEb5QJpJ3QmiHBD5U5lGjWgBGKDdxolu1A=w1920-h1080-s-no-gm
The caliper looks good
AP1GczPa564XgBSamOscASreRIHTgVNo-ZDca_hhjEmXBj-sMexFIYD8-3YCSTAAYNyvKc4nQv4845oX5NCfrodXMPnCcdKV6n2I8orVB9_CUzgUO65E4HB243NEWW3rqnnZK-kQckhj8VksR1CA7IxAB9zv8w=w1920-h1080-s-no-gm
The rust was also visible on the inside
AP1GczPGykgLM7MGXOlMH9VhJxYgsOvxN_KEncjwl1hM6uMcaY_jWsDQGAfioWBTWA6a3sVgg3UmAfzrW8G19aECVHUxTdVNrtZbD-YvM-ieJigSqdYvfc8pvCusM5xcL3u8JttresFVb_VQRBIBg05GzliwEQ=w1920-h1080-s-no-gm
Both rear calipers look like this. So they both need a little cleaning and paint
AP1GczOSyMXaBTH-irQLXhnOwwqtRSOWZuJXpHF38UCdS0trHb3tazqVf7GJP0Z70AjOZ_h8A0d4TXTT22DViXm6FrrTf5Kk4K6UTM2klD9NFr9WHGtqHHL-NrWILS3HsW5y8POzCMvOv7Z6quVFJfd-7mtbew=w1920-h1080-s-no-gm
The rear was rusty af, so new backing plates will be mounted.
AP1GczN4eE0p18mjzVWgaWTfE431fIsyQMzl4ImE-PhZ21NnVHLP5Q0F2_qeC-DXqN0pR3XCW4lTGYbd4xgtfu6U1wrk3f7sKsmVLZMa6yiemicegOoGmnxZ45tP0oaHS7r7AJWySBUedsOO2qmaOJdWCNh_qw=w1920-h1080-s-no-gm
Same goes for the arms, they are rusty and will be replaced.
AP1GczNj-OMxCppC0-LFSBSMYHXHIqmgcAvaLPHf_EAsyWS2ysBJB2k2auvlUkJwdQ2LvS2jPDb4BHd1mem0Si5qgkyeULwwPbyOSdC8iTxMGnEPcFFwBhiH5cOkk3_bi37Lou1ykaXj1gIR5s47gL8b4xga-w=w1920-h1080-s-no-gm
TripleBob
351
252
Not gonna lie I’m not a fan of the burnt tips - they’re a bit too JDM/Subaru for my liking. Personally I’d have kept your previous ones, or looked at a set of Akrapovic style carbon ones
But if you’re happy then who the heck cares? 👍😎
nd-photo.nl
4,222
360
The Netherlands
youtube.com
@TripleBob I also tried out the "pikey r600" mod, but reverted that as I wanted to retain that airflow on that side of the engine. I dont know why, but I feel better knowing that air is also cooling some stuff in that part of the engine bay.
I believe in my air diverters, so I havent removed them and checking the butt dyno if they made a significant change :LOL:
Even though I like my current intake, I will probably end up buying this oversized RamAir intake:
Reactions: TripleBob
