Just found out from the seller that it is meant to be there so im happy with that, just waiting on heat wrap so can wrap it...
Done a fair bit of work there mate, well doneSounds like you're chuffed with it.
Did you ever get that snapped stud for the rocker cover replaced?
10000k HIDs - I take it you don't actually want to see where you're going then? lol. They will be crap for night-time vision, even in projectors. If its just to look blue then they'll certainly do it!
Best HIDs for vision are 4300k, most people run between 4300k and 6000k![]()
Hi mate..on the N249 were does the bottom
silicone pipe lead to pls?
If you follow the hose from FPR it goes under the inlet manifold. Remove the old hose and installed 4mm silicon hose from under the inlet to your dump valve and then t-piece to your FPR.
