mk1 golf caddy/homemade 24v v6 4wd turbo
powernut
475
not too mutch to add as yet , due the stressfull dash wireing ,, makeing slow progress but , so its some progress ,, so 2day i neeeded a break an decided to find some cheep seats after a quick clean i think they will do the job as they evern have runners so , easy to adapt
nice flat backs too ideal i reckon for a caddy
and i was going to fit a golf ball type gearknob but it dosent look right after bending the gearstick , so had to buy a nice 4 motion one to match the runing gear
powernut
475
right small start on the wishbones
first some solid round bar
then cut and weld in place
and bit of black spray poped on and refit
may help a bit i supose
powernut
475
then made a decent strong box for the seat mount that shouldnt go any were soon ,and add some chassi strengh too ,
then add to make a few adjustments as im 6ft 5 and not a lot of room with the size of the dash in a caddy ,,
have to get more steel to finsh the other side lol
i was looking under the wear the old leaf springs used to be and the chassi and wasnt happy with it , so , it had to be ripped out ,
as ive now realiseing i need a stronger chassi
fits bang on inside the caddy chassi ,
carnt see that buggar going any were soon
powernut
475
hi all ha a bit of a bad day 2day , due nearly loseing my caddy , (luckly next door neibougher was in )yesterday afternoon had a local visit of the gipsy scum bags. who came with a highab truck,pulled onto my drive wraped a chain around the caddy and pulled it to the end of the fence ,then there was just about to put the hydrolic grab thew the roof to go scrap it , lucky neibougher came out and said what the hell are you doing,thats the guys caddys which hes repaireing , ,he said ive knocked twice andtheres no answer ,so looks like its scrap ,so was removeing it ,, (cheeky f.....kers arnt they ) so , i thought its time to move :music:, quicky bolted things up thew the wheels on and off i went hopefully maybe a bit more sercure here :)
powernut
475
well not too mutch to add at the moment
so snap off , steering wheel arrived ,and fits spot on with the electronic steering
and thought id chop the ecu loom to fit a contector to try match standalone to stock mk3 golf wireing plug and what a stressful job ,, lol mind finaly all cut ,colour colourd and wired up ready for re fitment
powernut
475
well not mutch to add , as i blow the stand alone ecu ,start of last week,with a coil back feed grrr , so , more re strip of wireing and repairing ,but after a week ,managed to refit the parts and pop a quick few map/setings to get it runing ,(stressfull with settings lol/
then thought might as well add the wideband , another headack ,because of were the exhaust is i had to make a hole back of the bulk head (2 layers of steel ) then because of the large plug , had to attempt to resolder stainless wire (nighmare /with a soldering iron lol) now sorted
(still no gauges working thow/speedo/works lol
thought id add the led for the wideband heater flashers til its ready , works a treat
short video of the ms video ,, needs more tuning ,but now main problems are sorted as well as i wire had come off in the ms contector causeing stress
View My Video
more tuning when the intercooler is piped and sorted
powernut
475
not mutch to add ,thought id have a hour at makeing a fuel tank ,
first lump of stainless, should add some extra weight balance too
then tryed out my plazma cutter great piece of kit
then a quick buzz around with the welder lol
filled it with water to check my welds lol (leak free left it for a hour )
top and pipes to sort 2moz
a dam oil leak too ,, another prob to be sorted
height of the caddy /it will have to do
powernut
475
bit of tank makeing 2day ...
more plazma cutting
quick zip around for fuel sensor
then a couple of tempory fits ,,nicely clears anti roll bar
make a few fasterners tomoz ready for fuel pipe work next
powernut
475
sorted bluetooth ,lol had to mean dam microwave too lmao ,, i must be a jack of all trades
powernut
475
well managed to sort a few bits this after , first made some fuel lines for the caddy
next deceied to chop the fuel flap out the boady
rare site lol, inside ,rot free
then went around the other side and chopped another hole out for the to refit the feul flap
not bad for a trail cut ,there was a slight gap so ,thought id add a filler rod , and welded up nicely
quick weld up
and grinded off
powernut
475
then oppss first thought id welded it wrong because its upside down ,must have got a bit carryed away , but i pref it to open this way lol ,little late now anyway
then a quick filler neck start on the pipe
right 2day noticed the camber sticks out more on the fronts to the rears dose this wheel look ok to you guys as i think the botom of the wheel is towing out to mutch ?
as after i was looking at the rear they had way too mutch inwards camber , maybe ok for corners ,but not very good for scrubing tyres off , and what a dam stressfull trying to algin the wheel, after getting it a tad lower i carnt risk anymore , so altered all the arms and also insurted a smaller box and stick welded them for extra strengh
powernut
475
not mutch to add due ringing around for a reasobable insurance , bit more welding and passenger seat frame started
old seat frame removed
seatbelt mount inner and outer sill nicely welded up
new suport welded in place and just started makeing new seat frame to fit my other seat
powernut
475
a cheep boost gauge came along too unsure if ill use it thow seems a bit big
quick pic of the re alinged wheel too ,dam thing lol
powernut
475
right got fed up off seen that oddy gearstick , , so thought chuff it rip the lot out and move it all ,
then plated all the inner sides /front and rear up
then made a fresh gearstick mount
ground it up as i had to add a 1inch to nothing angle , otherwise it wouldnt have cleared the propshaft as i dont want to removeing this again
just need to add a small plate and slighty alter front cables
least remotes high enoegh
few shots of a rough fit ,
1st gear
2nd gear loads more clearance
getting there now ,
but as i removed gear selector ive now got to cut the handbrake out next and move that too ...more fun
powernut
475
handbrake modifyed and moved something else sorted
then rewelded and tubes re shaped under car
bent the tubes out around the bulkhead and gave them a quick re weld
just made a quick repair of the leather handbrake leaver too [LOL]
quick refit and nicely working again
powernut
475
bit more tunnel modifying was needed this after
thought might as well get the propshaft in and make it a bit more leval/central
as it would have meant removeing lots of things to re fit it at a later stadge
bit more upside welding 2day lol managed to get a hour to make and fit the propshaft 2day ,,,,
mount
couple of propshaft pics
powernut
475
i think this will do the joby , another modifyed part lmfao
bit more modifying today , first decided to make the gearbox mount shorter for more road clearnace , seems better , (nearly 2 inch removed)
more choping
then went radiator hunting as that needed modifying too
then started choping that too as i wanted a big core , for decent cooling
then removed the water pipes so they were on the same side of the rad
thought id have a go at radiator repairing lol
also added a bigger fan switch too
rough fit
then added a fan , i may add too depending on how it cools the engine
plenty of clearance now at the front
started with some pipe work seems to fit ok
some quick brackets made and radiator done, i reckon it fills a hole lol
powernut
475
know the joint which i removed were also solderd , ie inlet/outlet/drain plugs as well the main core and end caps are solderd on so i reckon it will be fine
flows thew the cores now ,,,
all bolted back and wired fan up works a treat , also fitted a 75deg themostatat and fan sensor
next a start on the boost pipes ,looking a bit more like a engine
may get a bit more time 2moz to do a bit more
powernut
475
more progress today
first needed to cut some lumps of stainless for intercooler , spot on with plazma cutter
quick pic of the intercooler
adjustable wastegate arrived too
then cut a lump out of the front , glad really as it was rotton inside
trail fit //it ull do
then welded the stainless and boxed it off
intercooler fitted
then added some boost hose and 4ply blue contectors along with some hefty clips
powernut
475
i had to make the other as it was a tight spot
nicely fits
job done and bonett shuts too
