mk1 golf caddy/homemade 24v v6 4wd turbo
powernut
475
it will be runing again soon ,, ,,,with attempting more boost too lol my aim is 25psi , and i wont give up till i hit my target ,lol , i do personly know these engines hold it , ,the power it kicked up was a right eye operner ,i had major torque steer , basicly draging the caddy left to right up the road , so thought has to be a way , so i thought i know what will work , remove the driveshafts and make them both tubiler so they can only slightly flex , did this went for a spin , and wow , totaly differnert ,,,,it grip pulled and went fine with only very light torque steer , next thing was try the 4wd system ,, and i have to say it toaly transformed the caddy , amazed ,(evern if i say so myself ,lol) ill get some pics up of the build in progress ,,
powernut
475
gutted... clicked over from page 12 to 13 and there was no media links. Can't wait to see the caddy in action once its up and running again.
ill pop link here but it wasnt anthing good , as i recoreded the wrong part and had engine troubles as ull see , hitting the arounda bouts , anyone who dosent like swear words turn the sound off near the end lol
http://tinypic.com/r/n1rw2o/3
another engine arrived this afternoon ,,,
spare flywheel little rusty but feels half decent lol
give me something to ticker with and im going to leave the alloy sump on this one ,just to be safe
air121005
1,609
Worcestershire
:( sorry to read you've killed the engine...... but following this thread, not suprised you've already got another delivered! :clap::worship: fair play to you!!!
was the fatal moment as you were turning left at the 1st roundabout in the vid?
that was a hell of a bang/clunk......
powernut
475
yearh sound a lot worse then in the video , and found that was the dual mass that was on its least legs ,
powernut
475
bit of gernal stripping checking this after to make sure the engine is in decent , i was actury suprized when i removed the sump , very clean in there,
checked all the shells mains and oil pump
next rocker and clyinder head removed
checked the bores and there no lips at all nice clean smooth bores is always a good sign
also decieded i thought id treat myself to a new steel single mass flywheel to do away with all that dual mass crap
just finshing off the homemade headspacer , saves removing other too
powernut
475
how did you cut the head spacer?
easy lol draw around a size bigger headgasket .i.e r32 golf which are 84mm bores , when i cut it out with the plazma cutter it leaves the bore holes to 82mm spot on the correct size , for my lump ,,
powernut
475
Oh! I understand what you mean now! Still its impressively neat and I still think you must have a steady hand! Lol. Your very good at what you do! :D
thanks always nice to have a decent coment ,,,or 2 :D
the plazma will cut 5mm steel clean thew fst as u can move the trigger lol
finished it off today, im happy with it so its getting thown on lol
quick clean up and check of the head
found a bit of vw dove blue paint too , lol so addded some to the block
ill get the clyinder all refitted and torqued back up 2moz ,and look work start on stripping my old unit out ,,;)
Nov 29, 2007
736
Mansfield, Notts
I'm so gutted that I don't have the time or tools to strip and build a motor... Something I've always wanted to do and will one day I hope.
Mega impressed with your efforts mate...
powernut
475
just have a go its the only way ull get to do it ,, basic tools do the job nicely ,,,i just have a go ,, ;)
Ibiza 130 tdi
Black Magic
Jan 15, 2007
6,275
Somerset
Dude! Epic! Fair shout for custom making everything! There's getting mods done, then there's making mods! :lol:
Good luck with the Caddy - what a beast when you get it done! :drool:
Will you not need a bigger intercooler for that sort of power?
