mk1 golf caddy/homemade 24v v6 4wd turbo
powernut
475
Dude! Epic! Fair shout for custom making everything! There's getting mods done, then there's making mods! :lol:
Good luck with the Caddy - what a beast when you get it done! :drool:
Will you not need a bigger intercooler for that sort of power?
thanks guys for the replys , i just have a go ,regards intercooler it suports 450bhp , ive run/boosted the engine up to 27psi ,lol before the crank let go , and found out why , it was the dam engine sump ,, as i used a mk3 vr6 sump bolted on to the mk4 engine and i wasnt aware the oilpickuppipe was basicly flat to bottom which caused oil starvation grrr , so ill be useing the alloy one this time , (ill just try and have to watch out for speed humps ,,:cry:
might get a bit of progress 2moz , and ill had a few pics,,,:rolleyes:
powernut
475
had a spare hour to day so thought id prep the head for the low compression spacer and gasket instail first
split the new gasket as i dont need the middle shim
tin of copper sealer
then use copper head sealer on the block
fit the botom layer
then compression spacer
then top part of gasket
then fit the head and torque the head in the correct order
then get some bars to make sure the varible cam pulleys are tight lol and double checking the timing as well
air121005
1,609
Worcestershire
nice work :clap:
whilst the engines out, are you painting the engine bay?
don't think i've missed this, but have you decided on a colour scheme in general yet?:shrug:
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
this is a sick project! I love the fact you putting a completely unique engine in a caddy. Here in holland you see golfs/caddys with g60 engines or 20vt and sometimes a vr6. But never seen this.
Real eager to see this result. Should be awesome
well done
powernut
475
cool i like a try differnert ideas guys..... i know its works , and if it wasnt for the dam wrong/sump/oil id have still been runing ,,
i decided to rip the lot back out lol
pic of the upratted shaft see if i can snap this buggar lol
riped out
old nasty lump lol
new one awaits
and had to re grind part of the turbo manifold i made as the flange was blowing a bit , and nicely fitted and niped up
ill get the rest rebuilt up 2moz
then theres a few bits in the engine bay to be modifyed
while i await the new flywheel to arrive
powernut
475
only crazy when the right foot is floored lmao
only had 3 hours this after so a few updates
first clean and fitted new oil filter and houseing
then made a fresh oil feed for the turbo , bit of brazeing was needed lol
made a new fitting for the turbo feed
fits a treat
then re made a new oil return with a 19mm bore in a better location
fit spray and fit of the engine ancillers
slightly alterd the engine mount too , and added a bit more weld
and just had time to cut weld a quick plate in under the engine mount
powernut
475
cheers , ill be bisy at work , so might be a few days before i get any more , unless i find a few free hours lol
